Hi.
I recently added a new steinel xled zwave device to OH 2.1 (zwave nightly 16 th september). It is a Multichannel device.
Two times already after adding node or restart all channels got updates like this „NODE 110: Updating channel state zwave:device:a91aa612:node110:alarm_burglar to OFF“
But over night no updates come for channel burglar which worked the evening bevor. Nothing was changed, no reboot, no changes anywhere.
All other linked channels of the node are still working.
Also in that 9 Hours of Night 8 zwave log files were written, seems to much.
Log files with working and not working (burglar not updating)node are existing but I am not allowed to upload them since I am new user.
The device and the zwave stick are neighbouring nodes (according to OH), they are approx 5 meters and two walls between them.
Any idea?
Nork
Log, when everything was working (burglar alarm notification)
2017-09-18 22:05:06.106 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 110: Starting initialisation from DONE
2017-09-18 22:05:06.107 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 110: Incoming command class ALARM
2017-09-18 22:05:06.107 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 110: Received ALARM command V4
2017-09-18 22:05:06.107 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 110: Process NOTIFICATION_REPORT V4
2017-09-18 22:05:06.107 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 110: NOTIFICATION report - 0 = 0, event=8, status=255
2017-09-18 22:05:06.107 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 110: Alarm Type = BURGLAR (0)
2017-09-18 22:05:06.108 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 110: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2017-09-18 22:05:06.108 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 110: Got a value event from Z-Wave network, endpoint = 0, command class = ALARM, value = 255
2017-09-18 22:05:06.109 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 110: Updating channel state zwave:device:a91aa612:node110:alarm_burglar to ON [OnOffType]
2017-09-18 22:05:06.241 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 110: Application Command Request (ALIVE:DONE)
2017-09-18 22:05:06.241 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 110: Starting initialisation from DONE
2017-09-18 22:05:06.242 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 110: Incoming command class BASIC
2017-09-18 22:05:06.242 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 110: Received Basic Request
2017-09-18 22:05:06.242 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 110: Basic Set sent to the controller will be processed as Basic Report
2017-09-18 22:05:06.242 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 110: Basic report, value = 0xFF
2017-09-18 22:05:06.243 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 110: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2017-09-18 22:05:06.243 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 110: Got a value event from Z-Wave network, endpoint = 0, command class = BASIC, value = 255
2017-09-18 22:05:06.243 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 110: Updating channel state zwave:device:a91aa612:node110:switch_binary to ON [OnOffType]
2017-09-18 22:05:07.991 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 110: Application Command Request (ALIVE:DONE)
Log, when no longer alarm notification
17-09-19 10:38:31.889 [DEBUG] [class.ZWaveMultiInstanceCommandClass] - NODE 110: Requested Command Class = SENSOR_MULTILEVEL (0x31)
2017-09-19 10:38:31.890 [DEBUG] [class.ZWaveMultiInstanceCommandClass] - NODE 110: Endpoint = 3, calling handleApplicationCommandRequest.
2017-09-19 10:38:31.890 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 110: Received COMMAND_CLASS_SENSOR_MULTILEVEL command V4
2017-09-19 10:38:31.890 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 110: Sensor Multi Level REPORT received
2017-09-19 10:38:31.890 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 110: Sensor Type = Luminance(3), Scale = 1
2017-09-19 10:38:31.891 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 110: Sensor Value = 2.00E+3
2017-09-19 10:38:31.891 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 110: Got an event from Z-Wave network: ZWaveMultiLevelSensorValueEvent
2017-09-19 10:38:31.891 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 110: Got a value event from Z-Wave network, endpoint = 3, command class = SENSOR_MULTILEVEL, value = 2.00E+3
2017-09-19 10:38:31.892 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 110: Updating channel state zwave:device:a91aa612:node110:sensor_luminance3 to 2000 [DecimalType]
2017-09-19 10:38:31.894 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 110: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2017-09-19 10:38:31.894 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 110: Response processed after 212ms/4917ms.
2017-09-19 10:39:28.759 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 110: Transaction not completed: node address inconsistent. lastSent=110, incoming=255
2017-09-19 10:50:32.130 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 110: Transaction not completed: node address inconsistent. lastSent=110, incoming=255
2017-09-19 10:50:32.340 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 110: Transaction not completed: node address inconsistent. lastSent=110, incoming=255
2017-09-19 10:50:32.555 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 110: Transaction not completed: node address inconsistent. lastSent=110, incoming=255
2017-09-19 10:50:32.769 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 110: Transaction not completed: node address inconsistent. lastSent=110, incoming=255
2017-09-19 11:08:11.138 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 110: Polling...
2017-09-19 11:08:11.139 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 110: Polling zwave:device:a91aa612:node110:switch_binary
2017-09-19 11:08:11.140 [DEBUG] [converter.ZWaveBinarySwitchConverter] - NODE 110: Generating poll message for SWITCH_BINARY, endpoint 0
2017-09-19 11:08:11.141 [DEBUG] [dclass.ZWaveBinarySwitchCommandClass] - NODE 110: Creating new message for application command SWITCH_BINARY_GET
2017-09-19 11:08:11.141 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 110: Polling zwave:device:a91aa612:node110:scene_number
2017-09-19 11:08:11.142 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 110: Polling zwave:device:a91aa612:node110:sensor_binary
2017-09-19 11:08:11.142 [DEBUG] [converter.ZWaveBinarySensorConverter] - NODE 110: Generating poll message for SENSOR_BINARY, endpoint 0
2017-09-19 11:08:11.142 [DEBUG] [dclass.ZWaveBinarySensorCommandClass] - NODE 110: Creating new message for application command SENSOR_BINARY_GET
2017-09-19 11:08:11.143 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 110: Polling zwave:device:a91aa612:node110:sensor_luminance
2017-09-19 11:08:11.143 [DEBUG] [erter.ZWaveMultiLevelSensorConverter] - NODE 110: Generating poll message for SENSOR_MULTILEVEL, endpoint 0
2017-09-19 11:08:11.143 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 110: Creating new message for command SENSOR_MULTI_LEVEL_GET
2017-09-19 11:08:11.143 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 110: Polling zwave:device:a91aa612:node110:alarm_burglar
2017-09-19 11:08:11.144 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 110: Polling zwave:device:a91aa612:node110:alarm_system
2017-09-19 11:08:11.144 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 110: Polling zwave:device:a91aa612:node110:switch_binary1
2017-09-19 11:08:11.144 [DEBUG] [converter.ZWaveBinarySwitchConverter] - NODE 110: Generating poll message for SWITCH_BINARY, endpoint 1
2017-09-19 11:08:11.145 [DEBUG] [dclass.ZWaveBinarySwitchCommandClass] - NODE 110: Creating new message for application command SWITCH_BINARY_GET
2017-09-19 11:08:11.145 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 110: Encapsulating message, instance / endpoint 1
2017-09-19 11:08:11.145 [DEBUG] [class.ZWaveMultiInstanceCommandClass] - NODE 110: Creating new message for command MULTI_CHANNEL_ENCAP endpoint 1
2017-09-19 11:08:11.145 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 110: Polling zwave:device:a91aa612:node110:scene_number1
2017-09-19 11:08:11.146 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 110: Polling zwave:device:a91aa612:node110:alarm_burglar2
2017-09-19 11:08:11.146 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 110: Polling zwave:device:a91aa612:node110:sensor_luminance3
2017-09-19 11:08:11.146 [DEBUG] [erter.ZWaveMultiLevelSensorConverter] - NODE 110: Generating poll message for SENSOR_MULTILEVEL, endpoint 3
2017-09-19 11:08:11.146 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 110: Creating new message for command SENSOR_MULTI_LEVEL_GET
2017-09-19 11:08:11.147 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 110: Encapsulating message, instance / endpoint 3
2017-09-19 11:08:11.147 [DEBUG] [class.ZWaveMultiInstanceCommandClass] - NODE 110: Creating new message for command MULTI_CHANNEL_ENCAP endpoint 3
2017-09-19 11:08:11.148 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 110: Sending REQUEST Message = 01 09 00 13 6E 02 25 02 25 E5 6E
2017-09-19 11:08:11.160 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 110: Sent Data successfully placed on stack.
2017-09-19 11:08:11.217 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 110: SendData Request. CallBack ID = 229, Status = Transmission complete and ACK received(0)
2017-09-19 11:08:11.217 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 110: Starting initialisation from DONE
2017-09-19 11:08:11.294 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 110: Application Command Request (ALIVE:DONE)
2017-09-19 11:08:11.294 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 110: Starting initialisation from DONE
2017-09-19 11:08:11.294 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 110: Incoming command class SWITCH_BINARY
2017-09-19 11:08:11.295 [DEBUG] [dclass.ZWaveBinarySwitchCommandClass] - NODE 110: Switch Binary report, value = 0
2017-09-19 11:08:11.295 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 110: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2017-09-19 11:08:11.296 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 110: Got a value event from Z-Wave network, endpoint = 0, command class = SWITCH_BINARY, value = 0
2017-09-19 11:08:11.296 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 110: Updating channel state zwave:device:a91aa612:node110:switch_binary to OFF [OnOffType]
2017-09-19 11:08:11.299 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 110: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2017-09-19 11:08:11.299 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 110: Response processed after 151ms/4917ms.
2017-09-19 11:08:11.301 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 110: Sending REQUEST Message = 01 09 00 13 6E 02 30 02 25 E6 78
2017-09-19 11:08:11.311 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 110: Sent Data successfully placed on stack.
2017-09-19 11:08:11.427 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 110: SendData Request. CallBack ID = 230, Status = Transmission complete and ACK received(0)
2017-09-19 11:08:11.427 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 110: Starting initialisation from DONE
2017-09-19 11:08:16.302 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 110: Timeout while sending message. Requeueing - 2 attempts left!
2017-09-19 11:08:16.302 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 110: Got an error while sending data. Resending message.
2017-09-19 11:08:16.304 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 110: Sending REQUEST Message = 01 09 00 13 6E 02 30 02 25 EA 74
2017-09-19 11:08:16.316 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 110: Sent Data successfully placed on stack.
2017-09-19 11:08:16.377 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 110: SendData Request. CallBack ID = 234, Status = Transmission complete and ACK received(0)
2017-09-19 11:08:16.377 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 110: Starting initialisation from DONE
2017-09-19 11:08:21.305 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 110: Timeout while sending message. Requeueing - 1 attempts left!
2017-09-19 11:08:21.305 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 110: Got an error while sending data. Resending message.
2017-09-19 11:08:21.307 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 110: Sending REQUEST Message = 01 09 00 13 6E 02 30 02 25 EB 75
2017-09-19 11:08:21.319 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 110: Sent Data successfully placed on stack.
2017-09-19 11:08:21.378 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 110: SendData Request. CallBack ID = 235, Status = Transmission complete and ACK received(0)
2017-09-19 11:08:21.378 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 110: Starting initialisation from DONE
2017-09-19 11:08:26.308 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 110: Timeout while sending message. Requeueing - 0 attempts left!
2017-09-19 11:08:26.308 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 110: Got an error while sending data. Resending message.
