Hi there,
I will control four Hue bulbs with Alexa. But in Alexa should only be one thing visible.
Example:
One lamp with four Huw bulbs -> Alexa shows only “Livingroom Light”
Is it possible to group four bulbs together to one Alexa “Thing” with groups an not building blocks api?
Here is my code so far:
//Deckenlmape
Group DeckenlampeWZ "Deckenlampe Wohnzimmer" {alexa="Endpoint.light"}
//Deckenlampe rechts
Group DeckenlampeR "Deckenlampe rechts"
Dimmer DeckenlampeRWeis "Deckenlampe rechts Weis" (DeckenlampeR, DeckenlampeWZ) {channel="hue:0220:ecb5fa1dc19f:23:brightness", alexa="BrightnessController.brightness,PowerController.powerState"}
Dimmer DeckenlampeRTemp "Deckenlampe rechts Temp" (DeckenlampeR, DeckenlampeWZ) {channel="hue:0220:ecb5fa1dc19f:23:color_temperature", alexa="ColorTemperature.colorTemperatureInKelvin"}
//Deckenlampe mitte rechts
Group DeckenlampeMR "Deckenlampe mitte rechts"
Dimmer DeckenlampeMRWeis "Deckenlampe mitte rechtsWeis" (DeckenlampeMR, DeckenlampeWZ) {channel="hue:0220:ecb5fa1dc19f:21:brightness", alexa="BrightnessController.brightness,PowerController.powerState"}
Dimmer DeckenlampeMRTemp "Deckenlampe mitte rechts Temp" (DeckenlampeMR, DeckenlampeWZ) {channel="hue:0220:ecb5fa1dc19f:21:color_temperature", alexa="ColorTemperature.colorTemperatureInKelvin"}
//Deckenlampe mitte links
Group DeckenlampeML "Deckenlampe mitte links"
Dimmer DeckenlampeMLWeis "Deckenlampe mitte links Weis" (DeckenlampeML, DeckenlampeWZ) {channel="hue:0220:ecb5fa1dc19f:24:brightness", alexa="BrightnessController.brightness,PowerController.powerState"}
Dimmer DeckenlampeMLTemp "Deckenlampe mitte links Temp" (DeckenlampeML, DeckenlampeWZ) {channel="hue:0220:ecb5fa1dc19f:24:color_temperature", alexa="ColorTemperature.colorTemperatureInKelvin"}
//Deckenlampe links
Group DeckenlampeL "Deckenlampe links"
Dimmer DeckenlampeLWeis "Deckenlampe links Weis" (DeckenlampeL, DeckenlampeWZ) {channel="hue:0220:ecb5fa1dc19f:22:brightness", alexa="BrightnessController.brightness,PowerController.powerState"}
Dimmer DeckenlampeLTemp "Deckenlampe links Temp" (DeckenlampeL, DeckenlampeWZ) {channel="hue:0220:ecb5fa1dc19f:22:color_temperature", alexa="ColorTemperature.colorTemperatureInKelvin"}
Nils
