Hi @chris,
I updated the database for my YRD446 (link), with three config_decimal channels so that I can update parameters 2, 3, and 8. The xml (link) generates 3 channels listed as follows:
2: channel id="config_decimal_param2" typeId="yale_yrd446_00_000_config_decimal_param2"
3: channel id="config_decimal_param3" typeId="config_decimal"
8: channel id="config_decimal_param8" typeId="yale_yrd446_00_000_config_decimal_param8"
I think openhab doesn’t recognize the channel unless it is:
typeId=“config_decimal”
There is code further down:
<channel-type id="yale_yrd446_00_000_config_decimal_param2">
<item-type>Number</item-type>
<label>Auto relock</label>
<state pattern="%s">
<options>
<option value="0">No auto-relock</option>
<option value="255">Auto relock</option>
</options>
</state>
</channel-type>
<channel-type id="yale_yrd446_00_000_config_decimal_param3">
<label>Auto relock time</label>
</state>
</channel-type>
So, I’m only getting one “Parameter” channel in openhab for parameter=3, and I also have a “Auto Relock” channel for parameter=2, but nothing for parameter=8 is generated or shows up in habmin.
