Very well - as I do not use associations a lot, I am fairly sure these shouldn’t be there. But I will double check.
It has, second device in a row, on the same spot.
You are right that I did not mention this when posting the second occurence of the issue, however when the issue first occurred I did describe the trouble I had fixing the node, from which can be concluded the device was in a rather confused state, not just temporarily unreachable.
Yes, that’s what I wrote in my other reply in this thread. I had to set the node as failed and remove it using PC Controller.
Unfortunately I can’t check this any more as I have already removed the dead node.
I guess partly the “more information” you are referring to is already present in my other responses in this thread, and from those it can be concluded that this problem isn’t likely to be regular interference.
However, I realize I could have mentioned the device’s state in my follow-up response about the second occurence as well. I’m sorry for that missing piece of info and I will do my best to be more clear in future.
Again - I would suggest a word of caution! Don’t jump to the assumption that it is the same issue. It might be, but the number of times I see people make assumptions like this that force them to make prejudged decisions that are later shown to be incorrect is quite high.
It’s useful to consider, but I’d really not make any assumption at this point.
We are on the same page, Chris. I definately agree with you, we shouldn’t jump to any conclusions.
I know I have been having issues in this spot for a while now, and have the feeling that all these events are related to the same issue. But a feeling does not help much, that’s why I recently started monitoring/logging this.
I now have permanent debug logging on and a Zniffer coming in, so time will tell…
Indeed by design but by Polish programming odd things happen. c is such a raw thing . With multiple endpoints who knows how they have managed to get it wrong. Combine endpoint and nodeid badly???
The association tab. I think I have an image of one somewhere. I will see if I can track it down.
Well - by physics really. If there’s only 8 bits being used, then it can only be a number between 0 and 255. Anything else is a display problem as a byte can ONLY hold that number.
That would be interesting.
I would be careful not to assume there is no bug in the Sigma software either That said, if it’s showing something like that, then there is clearly a problem elsewhere as well.
I’m still not really sure what you’re referring to, so it’s a little accademic. At the end of the day, if it’s 8 bits, it can’t hold a larger number and that is independent of the language. If it’s displaying a larger number, then that could be a bug in the display/interpretation of the information.
Nobody believes WHAT can be? An 8 bit number will physically only use 8 bits and can only store 0-255. There can be a bug in any language to display something different, but if the protocol, or memory allocation only physically allocates 8 bits, the it can physically only store a number from 0-255 as there is no room for anything else.
You assume it is a language with a byte data type that is all managed but it is c and the programmer might just have malloc a bit of memory and then made a mess of the boundaries.
In PC program they may have been lazy and just made it an int but who knows in the firmware other than the fibaro dev. You also assume that the pointer is not corrupt and pointing at the 8 bits that was allocated rather than some totally different bit of memory
No - I’m assuming that the protocol defines this as a byte. A byte is physically 8 bits and can only carry numbers of 0 to 255.
That’s why I said earlier that programs can have bugs, but the physics of a byte, and the allocation of a byte to a protocol can not provide a number of greater than 255 in a byte. That’s physics.
Anyway, it doesn’t really matter so I’ll close my input on this thread.
So, I just managed to deliberately reproduce this issue (or: these symptoms).
Current OH version: 2.5.2 (release).
I reproduced this issue by quickly toggling the wall plug (while connected to some LED lights), on and off multiple times. EDIT: toggles were performed from the OH web UI and not using the physical B button. After doing this for a while, things start lagging, and eventually the device goes offline. These effects are not suprising thusfar. However, now the device thinks it’s not included to the network anymore (signaling a red ring when plugged into the socket).
Note: Obviously I know that switching on/off quickly multiple times is not very normal user behaviour, but this problem also happens under normal usage (it only takes longer to trigger).
Anyway, the plug is now offline/excluded. Except for unplugging/replugging I haven’t done anything yet to fix it. If someone wants me to try something, let me know.
At 16:24:03 it went offline, and then came back online at 16:25:01 after just replugging it.
At 16:30:54 it went offline again, and now it thinks it’s excluded.
Does anyone have any ideas as to why this happens?
Suggestions for me to try?
Update: I have been continuing to troubleshoot this issue together with @robmac and @petergebruers (thanks guys!). Eventually I contacted Fibaro as we suspected an issue with the device firmware (or design). Fibaro have now acknowledged that indeed there is an issue and have notified me that they are working on a fix.
