Has anyone ever worked with the alarmdecoder binding (IP Bridge) and successfully displayed two keypads that control separate partitions (two different addressMasks)? I can get one keypad/partition to display correctly on the Basic UI just fine. It doesn’t matter which keypad I use, only one will display.
Here is my bridge:
Bridge alarmdecoder:ipbridge:ad1 [ hostname=“XXX.XXX.XXX.XXX”, tcpPort=10000, discovery=true, timeout=10 ] {
Thing keypad partition1 [ addressMask = “100”, sendCommands = true, sendStar = false ]
Thing keypad partition2 [ addressMask = “400”, sendCommands = true, sendStar = false ]
Here are my items that are assigned to the sitemap:
String Keypad1StatusText "Partition 1 [%s]" <siren> (GrpAlarm, GrpHome)
channel="alarmdecoder:keypad:ad1:partition1:text"
String KeyPad2StatusText "Partition 2 [%s]" <siren> (GrpAlarm, GrpHome)
channel="alarmdecoder:keypad:ad1:partition2:text"
Like I said, one will display on the sitemap just fine. I can choose either KeyPad1StatusText OR KeyPad2StatusText, but not both at the same time. I’m starting to think it’s not possible.
Any help would be greatly appreciated.
