Openhabian 3.2
Hello there,
I wondered, what would be the easiest way to check if an item matches a couple of different states in a rule.
The basic idea I had was to just add comma-separated states to the “changed to” section of the trigger, but as far as I understand the documentation, this does not seem to be supported. Could this be realized with a condition?
If this is not possible, I would strongly suggest adding this to the rule engine, as this seems to be a helpful use case.
PS: I am using the basic rules in the main UI.
Thanks for any advice!
