Hi There,
i want to control my shutter with the exec binding and run my script with the arguments from switch.
When i press it the log shows an error:
[ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule ‘Shuttercontrol’: An error occurred during the script execution: index=1, size=1
shuttercontrol.items
String shuttercontrol_shutter "Jalousieren" <shutter>
Switch shuttercontrol_gateway_run { channel="exec:command:shuttercontrol_gateway:run" }
String shuttercontrol_gateway_args { channel="exec:command:shuttercontrol_gateway:input" }
String shuttercontrol_gateway_out { channel="exec:command:shuttercontrol_gateway:output" }
shuttercontrol.things
Thing exec:command:shuttercontrol_gateway "CMD - Shutter Gateway" [
command="/etc/openhab2/scripts/shuttercontrol %2$s",
interval=0,
autorun=true]
shuttercontrol.rules
rule "Shuttercontrol"
Item shuttercontrol_shutter received command
logInfo(receivedCommand)
logInfo("1")
shuttercontrol_gateway_args.sendCommand(receivedCommand)
logInfo("2")
shuttercontrol.sitemap
sitemap shutter label="Jalousien"
Frame label="Stuff"
Switch item=shuttercontrol_shutter mappings=["up"="Hoch", "center"="Mitte", "down"="Unten"]
So, how i get fixed this? I tried to changed the item-type of shuttercontrol_shutter
to Switch
but than i got this “error”:
[WARN ] [rest.core.internal.item.ItemResource] - Received HTTP POST request at ‘items/shuttercontrol_shutter’ with an invalid status value ‘up’.
I’ve read that switches only can store ON
and OFF
but in reason of possibility to define mappings in the sitemap i’m not sure if its true. And maybe item-type String
has no received command
event?
Lukas
