Hello all,
I’ve received my starter set of Hue LUX and configured them according to the Wiki on Github. But I observed the following quirks:
- Switching the item to ON uses a very low brightness which varies between 17 and 45. But the lights never go really bright. Can I set the initial brightness value when turning the bulb on?
- The Switch item sometimes looses its status and sets back to UNINITIALIZED. Checking the events.log, the last event was indeed the ON with no later update. But checking rest API of the item, its in state UNINITIALIZED. Thus the slider for brightness is not shown in the UI. Turning the bulb off and on again, then shows the brightness slider.
Heres my config:
item:
Switch wz_kugellampe_1 "Kugellampe" <hue> (gEG_Lichter) {hue="2"}
Dimmer wz_kugellampe_1_dim "Dimmer Kugellampe [%d %%]" <hue> {hue="2,brightness;70"}
sitemap:
Switch item=wz_kugellampe_1
Slider visibility=[wz_kugellampe_1==ON] item=wz_kugellampe_1_dim
Any thoughts how to rectify this are appreciated.
Thanks much.
