- Platform information:
- Hardware: KVM based virtual machine with plenty of resources on HP/Intel hardware
- OS: OpenSUSE Leap 15.0
- Java Runtime Environment: java-10-openjdk-headless-10.0.2.0 java-10-openjdk-10.0.2.0
- openHAB version: openhab2-2.4.0
- Issue of the topic: Based on the example OpenHAB Exec Binding explained in detail on 433MHz radio transmitter example I have managed to setup rules which control some serial devices. After some struggles every thing now works as expected - except when I insert the sleep function. Then I get a ugly java dump in my log. (The send command executes in about 20 mSec. so it wil only be triggered in rare cases)
- Please post configurations (if applicable):
- Rules code related to the issue
Member of gDIOrelays received command
val num = triggeringItem.name.toString.split("DIOrelay_").get(1)
// while(rs485_send.state != OFF){
Thread::sleep(5) // <--- kills jre
if(receivedCommand == ON){
rs485_send_Args.sendCommand("#021" + num +"01")
}else{
rs485_send_Args.sendCommand("#021" + num +"00")
- If logs where generated please post these here using code fences:
2019-05-18 13:36:24.084 [ERROR] [access.reflect.ReflectionTypeFactory] - class org.eclipse.xtext.common.types.access.reflect.ReflectionTypeFactory cannot access interface jdk.internal.vm.annotation.Contended (in module java.base) because module java.base does not export jdk.internal.vm.annotation to unnamed module @32d54242
java.lang.IllegalAccessException: class org.eclipse.xtext.common.types.access.reflect.ReflectionTypeFactory cannot access interface jdk.internal.vm.annotation.Contended (in module java.base) because module java.base does not export jdk.internal.vm.annotation to unnamed module @32d54242
at jdk.internal.reflect.Reflection.newIllegalAccessException(Reflection.java:360) ~[?:?]
at java.lang.reflect.AccessibleObject.checkAccess(AccessibleObject.java:589) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:556) ~[?:?]
followed by several pages, full log at http://vink-slott.dk/aema2Uho/openhab.log
Should I use another java version or do the community have any other suggestions?
Klaus
