My new Smart Home Automation System with OpenHab2 - Work in progress -> Migrating to OpenHAB3 -> Migrating to OpenHAB 4
openhab 4 on raspberrypi 4: I added animations and dynamic icons to my energy widget
In this video I show you some of the graphic updates I’m doing to my ENERGY WIDGET, still under development.
I added some effects to make the icons dynamic, the color intensities and the movement speeds, all based on the current state of the system.
Using expressions and some mathematical formulas the result obtained allows you to visually render the real-time situation of the system.
To manage the new features I added other configuration options, in an attempt to make the widget as generic as possible.
You can always find the source of the widget on my GITHUB repository, at GitHub - domoticsduino/openhab-widgets
The usual thanks to whoever had the initial idea from which I took inspiration Energy Widget like in Home Assistant Demo
homeautomation smarthome raspberrypi automation openhab4
openhab in a nutshell on raspberrypi 4: 51. create your personal widget for openhab from scratch - tutorial
have you ever wanted an openhab widget that does exactly what you need?
in this video i show you how to create your own custom widget from scratch, without any advanced programming knowledge.
we’ll start with the basics and see together how to define the look of the widget, how to connect it to your openhab items and how to add interactive features.
it doesn’t matter if you’re a beginner or an openhab expert, this guide will walk you through the creation of your own custom widget.
openhab in a NUTSHELL on raspberrypi 4: 52. From linux updates to OpenHAB: system always at TOP
In this video I show you how to keep your Linux operating system, on which OpenHAB is installed, always up to date and how to update OpenHAB to the latest stable version.
By following these simple steps, you can ensure that your system is always secure and performant, and that you can take advantage of the latest OpenHAB features.
openhab in a NUTSHELL on raspberrypi 4: 53. Update openHAB as docker container with portainer and notes for windows
In this video I show you how to update an OpenHAB instance running as a DOCKER container, using the Portainer web interface.
We will also see the documentation regarding the update of an OpenHAB instance running on Windows.
With these simple steps you can always keep your OpenHAB-based Smart Home system up to date
openhab in a nutshell on raspberrypi 4: 54. i used shell commands to update docker container
In this video i upgrade openhab from version 4.2.0 to version 4.3.3 using shell commands to update the running docker container image.
This process is applicable to all operating systems that docker can run on.
openhab in a nutshell on raspberrypi 4: 55. protect your smarthome, perform a complete openhab backup !
if you use openhab on openhabian, backup is essential.
in this guide i will explain how to create a backup, to restore your system in a few minutes.
don’t risk losing hours of work, watch the video and learn how to backup openhab!
homeautomation smarthome #domotic raspberrypi automation
openhab in a nutshell on raspberrypi 4: 56. openhab as container docker? here’s how to do a backup correctly
openhab on docker: fast and easy backup!
in this video, i will show you a quick and easy way to backup your openhab system running as a docker container.
stop wasting time and protect your data with a few simple steps.
openhab in a nutshell on raspberrypi 4: 57. how to restore a backup on docker containers…and not only
Openhab on docker: let’s restore a backup.
In this video, i will show you how i restore openhab on docker containers.
The procedure on docker, compared to the standard one, is a bit more complex because you can only restore if the openhab services are stopped.
