openhab2 intall is at /opt/openhab2 on rpi. cannot get my.openhab to create uuid and secret. have added user openhab and openhab2, unfortunately they also have default passwords…sudo adduser openhab…openhab2
had to specify password, which may be where problem lies…
regardless, added both users to dialout group. have restarted openhab server. have reinstalled my.openhab jar. will not create uuid or secret.
please help. thanks in advance as i have had a lot of help previously from you guys and it has helped a lot!
Hi Branden_Smale,
Did you manage to solve this issue ?
I am also facing a similar issue but in my case uuid file is being created. However, secret file is still not created.
I tried all possible solutions including a fresh install but, no luck!
I just created a new file named secret at the same location where uuid file is present and pasted a randomly generated WEP-128 bit key. Then i updated my account with the same key and magically everything’s got working.
I just tried it. Installed my.openHAB addon via Paper UI.
The file userdata/uuid is creates in any case and once the addon is there, I can also see userdata/myopenhab/secret.
Entered both in my my.openHAB account and restarted my runtime I see
21:26:49.605 [INFO ] [o.myopenhab.internal.MyOpenHABClient] - Connected to my.openHAB service (UUID = c77049de-e5d0-45ab-94c6-xxxxxxxxx, base URL = http://localhost:8080)
Did you maybe not look in these locations for the files?
@belovictor It would be great if you could put this information on to https://my.openhab.org/docs, because it seems that this is nowhere yet documented for openHAB 2…
i created the files at the specified locations and put all info on my.openhab. server is still not communicating with online. i know oh1 had to specify my.openhab as persistence, how to do that with oh2?
WIth OH2 you can go to the paper UI then persistence and Install my.openhab. It’ll create those files for you, not sure if they overwrite what you have already.
After you install the my.openhab extension (currently found under “MISC”). What is the directory path to the secret file? There is no webapps folder in OH2 nor userdata folder. I have found the UUID via the REST API end point.
Ok, Now that I’ve found the UUID and Secret values and updated my.openHAB.org profile. I restarted the openhab service and see the following log lines (with modified my uuid and secret values). the website my.openHAB.org still shows “offline”.
2016-08-10 15:00:43.131 [DEBUG] [.myopenhab.internal.MyOpenHABService] - my.openHAB service activated
2016-08-10 15:00:43.145 [DEBUG] [.myopenhab.internal.MyOpenHABService] - Using secret at ‘/var/lib/openhab2/myopenhab/secret’ with content 'YYYYYYYYYYYYYYYY’
2016-08-10 15:00:43.146 [DEBUG] [.myopenhab.internal.MyOpenHABService] - UUID = XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX, secret = YYYYYYYYYYYYYYYY
2016-08-10 15:00:43.166 [DEBUG] [.myopenhab.internal.MyOpenHABService] - Using secret at ‘/var/lib/openhab2/myopenhab/secret’ with content 'YYYYYYYYYYYYYYYY’
2016-08-10 15:00:43.580 [DEBUG] [o.myopenhab.internal.MyOpenHABClient] - No connection, Item update is not sent
The first and obvious question: Is your Java up to date? You have to use Oracla Java (not OpenJDK) and at least version 1.8.0-101 of Oracle Java. Otherwise my.openhab will not work.
Java is installed as 1.8.0_65 but when i try to update with apt-get install, then it sais it is currently the newest version
java version "1.8.0_65"
Java(TM) SE Runtime Environment (build 1.8.0_65-b17)
Java HotSpot(TM) Client VM (build 25.65-b01, mixed mode)
$ sudo apt-get install oracle-java8-jdk
Reading package lists... Done
Building dependency tree
oracle-java8-jdk is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
By the way I am running openhab on Raspbian with RP3.
Here’s what I have done so far:
With Paper UI added the binding misc/myopenhab, checked with feature:list if installed properly.
Created an account at my.openhab.org with secret and uuid that i found in /userdata.
What am I missing?
I have found people suggesting myopenhab.cfg file similar to my.openhab 1.x to give security permissions so I created that as well in …/conf/services with :
