- Platform information:
- Hardware: Raspberry Pi 4, 4GB
- ZigBee controller: ConBee 2
- microSD card: 64GB
- microSD card for backup: 128GB (in USB card-reader)
- OS: Openhabian 1.7 (Raspbian GNU/Linux 11 (bullseye)) (install image file:
openhabian-pi-raspios32-202201271414-git08bc4ff-crcdd86375a.img.xz) - Java Runtime Environment: default (don’t know which it is)
- openHAB version: 3.2.0 - Release Build
- Issue of the topic: My semantic model config-page in the web-interface has stopped working
Dear all,
I recently setup OpenHab 3.2 on the above system. I now started setting up my ZigBee devices and ran into an issue …
I am using a ConBee 2 controller, for which I configured the Deconz Binding without issue. To become familiar with OpenHab 3 web-UI, I then configured a simple semantic model with a single color lamp with one channel for Color and one channel for Color Temperature. This initially worked and I was happy with how easy it was to setup everything!
But then I did something while playing around/editing the semantic model that now makes the config-panel for the semantic model hang like so:
The other config-pages still seem to work fine. This is my items tab, to give you a sense of the what the model looked like that I configured:
Unfortunately I do not recall what exactly I did that triggered this behavior (but I think that was editing some aspect of the light). But everything was done through the web UI and I assume, I should be unable to significantly break something there …
I tried looking at the error log using the debug-console (i.e. logging in with ssh -p 8101 openhab@localhost). I ran
openhab> log:exception-display
which gave the following output:
org.apache.cxf.interceptor.Fault: null
at org.apache.cxf.service.invoker.AbstractInvoker.createFault(AbstractInvoker.java:162) ~[?:?]
at org.apache.cxf.service.invoker.AbstractInvoker.invoke(AbstractInvoker.java:128) ~[?:?]
at org.apache.cxf.jaxrs.JAXRSInvoker.invoke(JAXRSInvoker.java:201) ~[?:?]
at org.apache.cxf.jaxrs.JAXRSInvoker.invoke(JAXRSInvoker.java:104) ~[?:?]
at org.apache.cxf.interceptor.ServiceInvokerInterceptor$1.run(ServiceInvokerInterceptor.java:59) ~[?:?]
at org.apache.cxf.interceptor.ServiceInvokerInterceptor.handleMessage(ServiceInvokerInterceptor.java:96) ~[?:?]
at org.apache.cxf.phase.PhaseInterceptorChain.doIntercept(PhaseInterceptorChain.java:308) ~[?:?]
at org.apache.cxf.transport.ChainInitiationObserver.onMessage(ChainInitiationObserver.java:121) ~[?:?]
at org.apache.cxf.transport.http.AbstractHTTPDestination.invoke(AbstractHTTPDestination.java:265) ~[?:?]
at org.apache.cxf.transport.servlet.ServletController.invokeDestination(ServletController.java:234) ~[?:?]
at org.apache.cxf.transport.servlet.ServletController.invoke(ServletController.java:208) ~[?:?]
at org.apache.cxf.transport.servlet.ServletController.invoke(ServletController.java:160) ~[?:?]
at org.apache.cxf.transport.servlet.CXFNonSpringServlet.invoke(CXFNonSpringServlet.java:225) ~[?:?]
at org.apache.cxf.transport.servlet.AbstractHTTPServlet.handleRequest(AbstractHTTPServlet.java:298) ~[?:?]
at org.apache.cxf.transport.servlet.AbstractHTTPServlet.doGet(AbstractHTTPServlet.java:222) ~[?:?]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:687) ~[bundleFile:3.1.0]
at org.apache.cxf.transport.servlet.AbstractHTTPServlet.service(AbstractHTTPServlet.java:273) ~[?:?]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:799) ~[?:?]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:550) ~[?:?]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) ~[?:?]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:602) ~[?:?]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1624) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1434) ~[bundleFile:9.4.43.v20210629]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:294) ~[?:?]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:501) ~[?:?]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1594) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1349) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) ~[bundleFile:9.4.43.v20210629]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:82) ~[?:?]
at org.eclipse.jetty.server.Server.handle(Server.java:516) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.HttpChannel.lambda$handle$1(HttpChannel.java:388) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:633) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:380) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:277) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:105) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.io.ChannelEndPoint$1.run(ChannelEndPoint.java:104) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:338) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:315) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:173) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:131) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:386) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:883) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1034) [bundleFile:9.4.43.v20210629]
Caused by: java.lang.StackOverflowError
at java.lang.RuntimeException.<init>(RuntimeException.java:51) ~[?:?]
at java.lang.IllegalArgumentException.<init>(IllegalArgumentException.java:42) ~[?:?]
at java.util.regex.PatternSyntaxException.<init>(PatternSyntaxException.java:59) ~[?:?]
at java.util.regex.Pattern.error(Pattern.java:2027) ~[?:?]
at java.util.regex.Pattern.<init>(Pattern.java:1430) ~[?:?]
at java.util.regex.Pattern.compile(Pattern.java:1068) ~[?:?]
at java.util.regex.Pattern.matches(Pattern.java:1173) ~[?:?]
at java.lang.String.matches(String.java:2024) ~[?:?]
at org.openhab.core.common.AbstractUID.validateSegment(AbstractUID.java:97) ~[?:?]
at org.openhab.core.common.AbstractUID.<init>(AbstractUID.java:76) ~[?:?]
at org.openhab.core.common.AbstractUID.<init>(AbstractUID.java:59) ~[?:?]
at org.openhab.core.items.MetadataKey.<init>(MetadataKey.java:42) ~[?:?]
at org.openhab.core.internal.items.MetadataStateDescriptionFragmentProvider.getStateDescriptionFragment(MetadataStateDescriptionFragmentProvider.java:72) ~[?:?]
at org.openhab.core.internal.service.StateDescriptionServiceImpl.getMergedStateDescriptionFragments(StateDescriptionServiceImpl.java:71) ~[?:?]
at org.openhab.core.internal.service.StateDescriptionServiceImpl.getStateDescription(StateDescriptionServiceImpl.java:63) ~[?:?]
at org.openhab.core.items.GenericItem.getStateDescription(GenericItem.java:409) ~[?:?]
at org.openhab.core.io.rest.core.item.EnrichedItemDTOMapper.considerTransformation(EnrichedItemDTOMapper.java:126) ~[?:?]
at org.openhab.core.io.rest.core.item.EnrichedItemDTOMapper.map(EnrichedItemDTOMapper.java:68) ~[?:?]
at org.openhab.core.io.rest.core.item.EnrichedItemDTOMapper.map(EnrichedItemDTOMapper.java:62) ~[?:?]
at org.openhab.core.io.rest.core.item.EnrichedItemDTOMapper.map(EnrichedItemDTOMapper.java:90) ~[?:?]
The last two lines
are repeated another ~1000 times.
To test if this issue is related with the semantic model config-page error, I did the following:
I cleared the console with log:clear, rebooted, and then tried opening the semantic model config-page. I now have a similar error log, when running openhab> log:exception-display (notice that the call-stack is a subset of the above error log):
I am very much stuck and would be thankful for any help regarding this. It might be important to note, that I did not yet update the Openhabian installation after setting up - I say this, if perhaps this is bug that has been fixed in the meantime …
I hope somebody has any suggestions and appreciate any feedback/input!
Thanks and kind regards,
Michael
