My Squeezebox times out after 20s (notification message)
I am running OH 4.1.0M3 on a windows PC with the Squeezelite-X app installed. Now when running this simple rule
configuration: {}
triggers: []
conditions: []
actions:
  - inputs: {}
    configuration:
      volume: 50
      sink: squeezebox:squeezeboxplayer:23787f5cb4
      sound: Rain1.mp3
    type: media.PlayAction
the player stops after 20s. I tried several locally stored mp3 files but all have the same issue.
Here the debug-log:
2023-12-01 09:24:53.932 [DEBUG] [handler.SqueezeBoxNotificationPlayer] - Playlist updated
2023-12-01 09:24:53.932 [DEBUG] [handler.SqueezeBoxNotificationPlayer] - Playing notification
2023-12-01 09:24:53.932 [DEBUG] [rnal.handler.SqueezeBoxServerHandler] - Sending command: 70:85:c2:dd:2a:27 playlist index 0
2023-12-01 09:25:14.192 [DEBUG] [handler.SqueezeBoxNotificationPlayer] - Notification message timed out after 20 seconds
2023-12-01 09:25:14.192 [DEBUG] [handler.SqueezeBoxNotificationPlayer] - Restoring player state
2023-12-01 09:25:14.192 [DEBUG] [rnal.handler.SqueezeBoxServerHandler] - Sending command: 70:85:c2:dd:2a:27 mixer volume 0
2023-12-01 09:25:14.192 [DEBUG] [handler.SqueezeBoxNotificationPlayer] - Removing notification message from playlist
2023-12-01 09:25:14.192 [DEBUG] [rnal.handler.SqueezeBoxServerHandler] - Sending command: 70:85:c2:dd:2a:27 playlist delete 0
2023-12-01 09:25:14.595 [DEBUG] [handler.SqueezeBoxNotificationPlayer] - Playlist updated
2023-12-01 09:25:14.595 [DEBUG] [rnal.handler.SqueezeBoxServerHandler] - Sending command: 70:85:c2:dd:2a:27 playlist index 0
2023-12-01 09:25:14.595 [DEBUG] [rnal.handler.SqueezeBoxServerHandler] - Sending command: 70:85:c2:dd:2a:27 time 0
2023-12-01 09:25:14.595 [DEBUG] [handler.SqueezeBoxNotificationPlayer] - Stopping the player
2023-12-01 09:25:14.595 [DEBUG] [rnal.handler.SqueezeBoxServerHandler] - Sending command: 70:85:c2:dd:2a:27 stop
2023-12-01 09:25:14.596 [DEBUG] [rnal.handler.SqueezeBoxServerHandler] - Sending command: 70:85:c2:dd:2a:27 mixer volume 7
2023-12-01 09:25:14.596 [DEBUG] [rnal.handler.SqueezeBoxPlayerHandler] - SqueezeBoxTimeoutException during notification: Notification message timed out
2023-12-01 09:25:24.846 [DEBUG] [rnal.handler.SqueezeBoxServerHandler] - Sending command: players 0
There is a callback URL which is in my case empty (default). Could someone give me some hints how to solve this problem?
You can set the notification timeout in the thing.
If you play a sound directly from openhab it’s a notification.
try playing a favorite from your squeezebox server.
Greets
Thing
configuration:
   notificationTimeout: 20
Oh many thanks. I had no idea that this timeout can be set in thing :slight_smile:
But for some reason the notification is shown in the player when running the rule. Now I do have the problem that the sound file is not starting (playing) anything! When running a radio station directly from the favorites it works.
Here a log:
2023-12-01 17:19:17.282 [DEBUG] [eezebox.internal.SqueezeBoxAudioSink] - Processing audioStream http://localhost:8080//audio/e8a100f2-61d4-4b9b-8524-7ade012e4457.mp3 of format AudioFormat [codec=MP3, container=NONE, channels=1]
2023-12-01 17:19:17.283 [DEBUG] [rnal.handler.SqueezeBoxPlayerHandler] - Play notification sound on player 70:85:c2:dd:2a:27 at URI http://localhost:8080//audio/e8a100f2-61d4-4b9b-8524-7ade012e4457.mp3
2023-12-01 17:19:17.283 [DEBUG] [ternal.handler.SqueezeBoxPlayerState] - Cur State: vol=0, mut=NOT MUTED, pwr=ON, stp=STOPPED, ctl=PAUSED, shf=OFF, rpt=OFF, tix=0, tnm=0, tim=0
2023-12-01 17:19:17.283 [DEBUG] [handler.SqueezeBoxNotificationPlayer] - Setting up player for notification
2023-12-01 17:19:17.283 [DEBUG] [rnal.handler.SqueezeBoxServerHandler] - Sending command: 70:85:c2:dd:2a:27 mixer volume 35
2023-12-01 17:19:17.384 [DEBUG] [handler.SqueezeBoxNotificationPlayer] - Adding notification message to playlist
2023-12-01 17:19:17.384 [DEBUG] [rnal.handler.SqueezeBoxServerHandler] - Sending command: 70:85:c2:dd:2a:27 playlist add http://localhost:8080//audio/e8a100f2-61d4-4b9b-8524-7ade012e4457.mp3 Notification
2023-12-01 17:19:17.785 [DEBUG] [handler.SqueezeBoxNotificationPlayer] - Playlist updated
2023-12-01 17:19:17.785 [DEBUG] [handler.SqueezeBoxNotificationPlayer] - Playing notification
2023-12-01 17:19:17.785 [DEBUG] [rnal.handler.SqueezeBoxServerHandler] - Sending command: 70:85:c2:dd:2a:27 playlist index 0
2023-12-01 17:19:23.988 [DEBUG] [rnal.handler.SqueezeBoxServerHandler] - Sending command: players 0
I also manually changed the volume etc. but it simply does not play.
Is this the right mp3 file?
I did a test now.
my file is
http://192.168.0.9:8080/audio/714da8ef-af78-4c35-a8ef-43d03df353b1.wav
My callback url is ‘http://192.168.0.9:8080’ (my openhab)
Maybe try to add your openhab ip..
Thanks now it works!
