Starting over and switching of the secure inclusion did not help much. Again “unknow device” shows up, waking it up manually does not help, removing the Thing etc. stuck at the very same spot…
So then I thought why not give 1.8.3 and Habmin1 a try… It worked within 5 minutes…:
- Opened the zwave binding in habmin 2
- Manually woke-up the WALLC-S: it appears as a WALLC-S, with all configuration parameters
- I changed the device configuration, the items are shown in yellow in HABmin,
- Manually woke-up the WALLC-S, items turn white (as in: configuration updated
- Changed Node 1 to " member" for all association groups “0 of 10 members”
- Manually woke-up WALLC-S: association is accepted “1 of 10 members”
I did the exact same thing, works in 1.8 but not in 2b4… So there must be a setting or something that I am missing…
I have logs for both 1.8 and 2.0B4 scenarios
Starting openhab2 I am back to where I started as described in this thread:
