I want to share my test results with the new z-wave binding:
I come from OH 2.3 stable, but I think most of my z-wave configs are with z-wave binding 2.2 stable. I run into a problem with z-wave 2.3 yesterday, so I decided to upgrade to lastest OH 2.4 snapshot and z-wave biding. Here are my results with my devices. I will continue if I get all my devices online again.
AEOTEC ZW112 door/window: work as before, no impact
Eurotronic Spirit radiator thermostat: works as before, no impact
Fibaro RGBW controller: works as before, no impact
Z-Wave WALLC-S Wall switch: works as before, no impact
Fibaro FGR222 roller shutter: works different as before
First, most of my settings are gone, I had to set them again. But what the bad thing is now. that the rollershutter reports position status not even if stops. It sends the position while running. This breaks some of my rules. I use autoupdate=false to get a position value only from rollershutter by itself. But the behaviour is different now. If I click on a button or send a command by OH the rolleshutter works but send me the position while running. With old binding I only got a new position value if the rollershutter stops running. Can anyone verify this?
POPP Rain-sensor 700168: Gives error message:
2018-11-24 15:57:07.547 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.initialize()' on 'org.openhab.binding.zwave.handler.ZWaveThingHandler@ce735': 1
java.lang.ArrayIndexOutOfBoundsException: 1
at org.openhab.binding.zwave.handler.ZWaveThingHandler.initialiseNode(ZWaveThingHandler.java:226) ~[?:?]
at org.openhab.binding.zwave.handler.ZWaveThingHandler.bridgeStatusChanged(ZWaveThingHandler.java:512) ~[?:?]
at org.openhab.binding.zwave.handler.ZWaveThingHandler.initialize(ZWaveThingHandler.java:164) ~[?:?]
at sun.reflect.GeneratedMethodAccessor248.invoke(Unknown Source) ~[?:?]
at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:153) [101:org.eclipse.smarthome.core:0.10.0.201811171951]
at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:53) [101:org.eclipse.smarthome.core:0.10.0.201811171951]
2018-11-24 15:57:07.562 [ERROR] [core.thing.internal.ThingManagerImpl] - Exception occurred while initializing handler of thing 'zwave:device:15a7a49f3a6:node14': 1
2018-11-24 15:59:31.466 [INFO ] [ommandclass.ZWaveVersionCommandClass] - NODE 13: Command Class COMMAND_CLASS_BASIC has version 0!
2018-11-24 15:59:32.468 [WARN ] [re.thing.internal.ThingFactoryHelper] - Could not create channel 'basic_basic_number' for thing type 'zwave:device:15a7a49f3a6:node13', because channel type 'zwave:basic_number' could not be found.
Device Fibaro FGK - 101 Firmware 2.5 gives me this error:
2018-11-24 16:13:46.400 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.initialize()' on 'org.openhab.binding.zwave.handler.ZWaveThingHandler@1944548': 1
2018-11-24 16:13:46.408 [ERROR] [core.thing.internal.ThingManagerImpl] - Exception occurred while initializing handler of thing 'zwave:device:15a7a49f3a6:node15': 1
2018-11-24 16:15:01.998 [WARN ] [ndclass.ZWaveAlarmSensorCommandClass] - NODE 42: Detected Fibaro FGK - 101 Door / Window sensor, only requesting alarm type Smoke.
The problem is this. I just click one time on the OH rollershutter item to go up. But it sends 31 in the middle of the way up and at the end if it stopps 100. I expect RS_RollerShutter_01 changed from 27 to 100 (start position and end position. 31 is somewhere in the middle and not interested in.
2018-11-24 18:28:26.818 [ome.event.ItemCommandEvent] - Item 'RS_RollerShutter_01' received command UP
2018-11-24 18:28:28.407 [vent.ItemStateChangedEvent] - RS_RollerShutter_01 changed from 27 to 31
2018-11-24 18:28:45.606 [vent.ItemStateChangedEvent] - RS_RollerShutter_01 changed from 31 to 100
2018-11-24 19:35:05.003 [ome.event.ItemCommandEvent] - Item 'RS_RollerShutter_01' received command UP
2018-11-24 19:35:20.092 [vent.ItemStateChangedEvent] - RS_RollerShutter_01 changed from 0 to 61
2018-11-24 19:35:30.282 [vent.ItemStateChangedEvent] - RS_RollerShutter_01 changed from 61 to 100
2018-11-24 19:51:09.176 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.thingUpdated()' on 'org.openhab.binding.zwave.handler.ZWaveThingHandler@9d41e3': 1
at org.eclipse.smarthome.core.thing.binding.BaseThingHandler.thingUpdated(BaseThingHandler.java:208) ~[?:?]
at sun.reflect.GeneratedMethodAccessor339.invoke(Unknown Source) ~[?:?]
2018-11-24 19:51:40.926 [INFO ] [ommandclass.ZWaveVersionCommandClass] - NODE 12: Command Class COMMAND_CLASS_MULTI_CHANNEL has version 0!
Since this is a very slow change, the repoll will just need to be disabled since it will only allow you to set it to 15 seconds. Disable this by setting to 0.
Probably not. I’m not sure why it would be 0 - it could be an issue with the device, or some sort of lost response during initialisation. Since most devices just use version 2, which is the default, it should be fine.
And another one - should I open a new post for every error to track each in a different post:
2018-11-24 19:53:48.706 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.thingUpdated()' on 'org.openhab.binding.zwave.handler.ZWaveThingHandler@1944548': 1
2018-11-24 19:53:52.738 [WARN ] [ndclass.ZWaveAlarmSensorCommandClass] - NODE 38: Detected Fibaro FGK - 101 Door / Window sensor, only requesting alarm type Smoke.
