myopenHAB not showing items
I have been trying to use IFTTT applets to trigger some of my items but I haven’t been able to do it since myopenHAB doesn’t show any items. I made sure in PaperUI>Services>OpenHAB Cloud Connector>Expose to expose my items but still nothing… Why is this happening and how can I solve it? Thanks!
I am using openHAB 2
Solved:
After “exposing” your items on the Paper UI, make sure you send a command through the basic UI first, otherwise myopenHAB won’t find the item. After that, you can remove the item from the sitemap if you want to.
Also, make sure openHAB servers work properly, sometimes you have to wait a couple minutes.
