I recently installed the openHAB Cloud Connector and I can view the “Home” sitemap in OH2, which displays the zwave items that I have setup in Paper UI (everything else is defined in text files). I also have a very simple sitemap with two entries that I am able to view through the basic UI locally. I can also access the “Home” sitemap from the iOS app, but get a “Request failed: internal server error (500)” error when trying to access the simple sitemap that I setup. Accompanying the error are the following entries in my openhab.log:
These entries are not really related to your issue. They occur with every remote access of the app (iOS and Android). There is an open issue somewhere for this…
If I understood you correctly, you have two sitemaps?
Does the remote access through your iOS app work for any of them?
I don’t think this is “forbidden”, but it’s not the official way. The local URL should be http://YOUR-IP:8080. Only the remote URL should be https://myopenhab.org.
One more thing: When you have defined both local and remote the same way, of course you get the above mentioned warnings with every access (as both access methods do run remotely).
For further examination of the issue, you should change the url as mentioned and then have a look what’s working and what’s not working.
I only have one sitemap defined. There is also a sitemap that shows up automatically named “Home” that shows Things that I have defined in Paper UI. If using a webpage from inside my network, I use the following URL to get to my simple sitemap:
I don’t know if this is relevant, but I have setup Nginx proxy using the option built into openHABian, then I limited access to Jetty to localhost (127.0.0.1). Nginx makes port 8080 on the local host available externally on port 80, which is why I do not have :8080 in the URL above that I can use to access the sitemap through my web browser. Using the following local URL in the iPhone app also gives the same error as trying to access the sitemap through the openHAB cloud service:
I also do have this sitemap.[quote=“j_wittenzellner, post:7, topic:22831”]
Yeah, maybe. I’ve seen some threads were people also had problems with the access while running nginx. But I can’t remember what was the solution for them…
But the functionality is OK.
It logs every action (click) i do with myopenhab app on my iPhone.
Both browsers, Safari and Firefox in ios are not giving these log info, and are working perfectly.
Any news on this? I see the same issue: iOS app works but I get [io.openhabcloud.internal.CloudClient] - Jetty request xxx failed: null where xxx is a 7 digit number.
One pattern that I see consistently is that the issue occurs (mostly) when I navigate groups, i.e. not actually manipulate an item but navigate.
Local URL: https://openhabpi:8080
Remote URL: https://myopenhab.org
Any ideas - does it matter?
