Hi.
I had a working OH1 installation in Windows, and copied the directory from Windows to CentOS 7 machine.
After some modifications, it’s now working.
However, my.openhab isn’t working yet.
It’s just saying that there is no connection.
I’ve tried deleting uuid
and secret
files.
Networking is OK at the machine.
Here’s are the details:
$ lsb_release -a
LSB Version: :core-4.1-amd64:core-4.1-noarch
Distributor ID: CentOS
Description: CentOS Linux release 7.2.1511 (Core)
Release: 7.2.1511
Codename: Core
$ java -version
java version "1.8.0_111"
Java(TM) SE Runtime Environment (build 1.8.0_111-b14)
Java HotSpot(TM) Server VM (build 25.111-b14, mixed mode)
And relevant snippet from the log:
17:42:24.485 [INFO ] [c.internal.ModelRepositoryImpl:80 ] - Loading model 'myopenhab.persist'
17:42:34.402 [DEBUG] [.m.i.MyOpenHABServiceActivator:27 ] - MyOpenHAB service has been started.
17:42:34.406 [DEBUG] [o.o.i.m.i.MyOpenHABServiceImpl:299 ] - setEventPublisher
17:42:34.407 [DEBUG] [o.o.i.m.i.MyOpenHABServiceImpl:134 ] - my.openHAB service activated
17:42:34.411 [DEBUG] [.p.internal.PersistenceManager:146 ] - Initializing myopenhab persistence service.
17:42:34.511 [DEBUG] [o.o.i.m.i.MyOpenHABServiceImpl:117 ] - config is null
17:42:34.513 [DEBUG] [o.o.i.m.i.MyOpenHABServiceImpl:175 ] - UUID file found at '/opt/openhab/openhab_distribution-1.8.3-runtime/webapps/static/uuid' with content '044e8a07-1366-4765-8fdf-011632077cb5'
17:42:34.514 [DEBUG] [o.o.i.m.i.MyOpenHABServiceImpl:227 ] - Secret file already exists at '/opt/openhab/openhab_distribution-1.8.3-runtime/webapps/static/secret' with content '...'
17:42:34.515 [DEBUG] [o.o.i.m.i.MyOpenHABServiceImpl:119 ] - UUID = 044e8a07-1366-4765-8fdf-011632077cb5, secret = ...
17:42:34.529 [DEBUG] [o.o.i.m.i.MyOpenHABServiceImpl:175 ] - UUID file found at '/opt/openhab/openhab_distribution-1.8.3-runtime/webapps/static/uuid' with content '044e8a07-1366-4765-8fdf-011632077cb5'
17:42:34.530 [DEBUG] [o.o.i.m.i.MyOpenHABServiceImpl:227 ] - Secret file already exists at '/opt/openhab/openhab_distribution-1.8.3-runtime/webapps/static/secret' with content '...'
17:42:34.531 [DEBUG] [o.o.i.m.i.MyOpenHABServiceImpl:161 ] - Version file found at '/opt/openhab/openhab_distribution-1.8.3-runtime/webapps/static/version' with content '1.8.3'
17:42:34.707 [DEBUG] [.myopenhab.internal.MyOHClient:137 ] - Manager.EVENT_TRANSPORT
17:42:34.826 [INFO ] [c.internal.ModelRepositoryImpl:80 ] - Loading model 'air_condition.rules'
17:42:34.940 [DEBUG] [.myopenhab.internal.MyOHClient:142 ] - Transport.EVENT_REQUEST_HEADERS
17:42:35.191 [DEBUG] [.r.i.engine.RuleTriggerManager:438 ] - Scheduled rule check_temp with cron expression 0 0/1 * * * ?
17:42:35.791 [DEBUG] [riptExtensionClassNameProvider:63 ] - Script actions have changed: ExecActionService, PingActionService, MyOpenHABServiceImpl, AudioActionService, AstroActionService, HTTPActionService, TransformationActionService,
17:42:36.545 [DEBUG] [o.o.i.m.i.MyOpenHABServiceImpl:281 ] - store(alarmTimeHour), state = 8
17:42:36.546 [DEBUG] [.myopenhab.internal.MyOHClient:477 ] - No connection, Item update is not sent
The only weird thing that I see here, is the config is null
- is it normal?
UPDATE
My log file seems similar to the one in [SOLVED] My.OpenHAB OffLine
There @belovictor diagnosed it as an SSL problem, and recommended replacing OpenJDK with Oracle Java.
But I’m already using Oracle Java…
Maybe it’s a problem with my Java version?
My some missing dependencies?
Basically, it’s a “Minimal CentOS” installation.
