I recently started experiencing problems with my MyQ device. I’m running openHAB 3.4 SNAPSHOT build 3014 on a Pi4B running openHABian.
This what I see in the log:
2022-08-01 14:01:09.662 [ERROR] [oauth2client.internal.OAuthConnector] - grant type refresh_token to URL https://partner-identity.myq-cloud.com/connect/token failed with HTTP response code 502
2022-08-01 14:02:13.058 [ERROR] [oauth2client.internal.OAuthConnector] - grant type refresh_token to URL https://partner-identity.myq-cloud.com/connect/token failed with HTTP response code 502
2022-08-01 14:02:13.561 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'myq:account:5c8e5ac110' changed from ONLINE to OFFLINE (CONFIGURATION_ERROR): Could not login with credentials
If I manually disable and reenable the MyQ Account Thing in the UI, it comes back online,
