Hi.
I have successfully installed OH2 and mysensors binding
bundle:list
214 | Active | 80 | 3.12.0.OH | nrjavaserial
215 | Active | 80 | 2.2.0.201710190834 | MySensors Binding
I created bridge as in tutorial here
My test node is seen and I added it to things via paperUI.
I created also item using paperUI.
From logs I can see that there is an communication
22:55:15.979 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 1;3;1;0;0;24.1
22:55:15.986 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 1 found in gateway
22:55:15.992 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 3 not present in node 1
22:55:16.474 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 1;255;3;0;0;77
22:55:16.481 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Battery percent for node 1 update to: 77%
22:55:16.486 [DEBUG] [ensors.handler.MySensorsThingHandler] - Updating channel: battery value to: 77
22:55:16.503 [DEBUG] [ensors.handler.MySensorsThingHandler] - Setting last update for node/child 1/1 to 2017-11-18T22:55:16.000+0000
But Iam unable to see values in items used in sitemap
sitemap test label="Main Menu"
Text item=TemperatureSensor01_Temperature label="node 1 [%.1f °C]" icon="temperature"
Text item=TemperatureSensor01_LastUpdate label="last update [%1$tA, %1$td/%1$tm/%1$tY %1$tH:%1$tM]"
Iam running on latest apt-get update & upgrade raspberrian
This setup worked on OH1 and node has forced id, because there was no method on OH1 to lease them.
edit 2017-11-19 It apears that LastUpdate is being set.
20:50:10.267 [INFO ] [marthome.event.ItemStateChangedEvent] - TemperatureSensor01_LastUpdate changed from 2017-11-19T20:47:11.000+0000 to 2017-11-19T20:50:10.000+0000
But no other values.
I created all items link in thing detail.
