I just found out that there is the possibility to track the ACK of a command to mysensors on item level and that you can see in the logs if the message was delivered successfully. Does somebody know if you can “catch” this missing ACK in a rule?
Would be great to cache the command and retry later on once the sensor is back…
thx!
regards
Markus
