Hey guys, i’ve been wondering if anyone know whats the problem with my configuration?
I have a soundbar which uses RC6 IR Codes (the one with the Toggle bit) in lenght of 20 bit. As soon as i send the IR Code without the toggle bit, i receive this warning.
2017-10-25 10:41:11.676 [WARN ] [rsAbstractConnection$MySensorsReader] - Exception on reading from connection
java.text.ParseException: class java.text.ParseException : Message length is not > 4
at org.openhab.binding.mysensors.internal.protocol.message.MySensorsMessage.parse(MySensorsMessage.java:336) [216:org.openhab.binding.mysensors:2.2.0.201710190834]
at org.openhab.binding.mysensors.internal.protocol.MySensorsAbstractConnection$MySensorsReader.run(MySensorsAbstractConnection.java:345) [216:org.openhab.binding.mysensors:2.2.0.201710190834]
Heres my debug log
2017-10-25 10:51:54.103 [ome.event.ItemCommandEvent] - Item 'Home_Mysensors_WZ_Soundbar_Generic_Control' received command MS_WZ_SOUNDBAR_POWER
2017-10-25 10:51:54.130 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 20 found in gateway
2017-10-25 10:51:54.135 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 1 found in node 20
2017-10-25 10:51:54.141 [DEBUG] [rsAbstractConnection$MySensorsWriter] - Sending to MySensors: 20;1;1;0;32;4,1100C,20
2017-10-25 10:51:54.144 [ome.event.ItemCommandEvent] - Item 'Home_Mysensors_WZ_Soundbar_Control' received command 4,1100C,20
2017-10-25 10:51:54.157 [vent.ItemStateChangedEvent] - Home_Mysensors_WZ_Soundbar_Control changed from 4,100C,20 to 4,1100C,20
2017-10-25 10:51:54.165 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 0;0;3;0;9;send: 0-0-20-20 s=1,c=1,t=32,pt=0,l=10,sg=0,st=ok:4,1100C,2
2017-10-25 10:51:54.168 [ome.event.ItemCommandEvent] - Item 'Home_Mysensors_WZ_Soundbar_Control_Switch' received command OFF
2017-10-25 10:51:54.174 [vent.ItemStateChangedEvent] - Home_Mysensors_WZ_Soundbar_Control_Switch changed from ON to OFF
2017-10-25 10:52:27.995 [ome.event.ItemCommandEvent] - Item 'Home_Mysensors_WZ_Soundbar_Generic_Control' received command MS_WZ_SOUNDBAR_VOL_UP
2017-10-25 10:52:28.005 [vent.ItemStateChangedEvent] - Home_Mysensors_WZ_Soundbar_Generic_Control changed from MS_WZ_SOUNDBAR_POWER to MS_WZ_SOUNDBAR_VOL_UP
2017-10-25 10:52:28.027 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 20 found in gateway
2017-10-25 10:52:28.031 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 1 found in node 20
2017-10-25 10:52:28.035 [DEBUG] [rsAbstractConnection$MySensorsWriter] - Sending to MySensors: 20;1;1;0;32;4,1010,20
2017-10-25 10:52:28.042 [ome.event.ItemCommandEvent] - Item 'Home_Mysensors_WZ_Soundbar_Control' received command 4,1010,20
2017-10-25 10:52:28.047 [vent.ItemStateChangedEvent] - Home_Mysensors_WZ_Soundbar_Control changed from 4,1100C,20 to 4,1010,20
2017-10-25 10:52:28.055 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 0;0;3;0;9;send: 0-0-20-20 s=1,c=1,t=32,pt=0,l=9,sg=0,st=ok:4,1010,20
2017-10-25 10:52:28.058 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received:
2017-10-25 10:52:28.061 [WARN ] [rsAbstractConnection$MySensorsReader] - Exception on reading from connection
2017-10-25 10:52:28.066 [vent.ItemStateChangedEvent] - Home_Mysensors_WZ_Soundbar_Control_Switch changed from OFF to ON
2017-10-25 10:52:28.070 [ome.event.ItemCommandEvent] - Item 'Home_Mysensors_WZ_Soundbar_Control_Switch' received command ON
The Item Home_Mysensors_WZ_Soundbar_Control_Switch represents my toggle bit.
Sometimes the controller is disconnecting: (Wasnt able to get any debug lof from it):
2017-10-25 10:41:16.803 [hingStatusInfoChangedEvent] - 'mysensors:ir:gateway:ir_20_1' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR)
2017-10-25 10:41:16.813 [hingStatusInfoChangedEvent] - 'mysensors:ir:gateway:ir_10_1' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR)
2017-10-25 10:41:16.828 [hingStatusInfoChangedEvent] - 'mysensors:bridge-ser:gateway' changed from ONLINE to OFFLINE
2017-10-25 10:41:16.840 [hingStatusInfoChangedEvent] - 'mysensors:ir:gateway:ir_20_1' changed from OFFLINE (BRIDGE_OFFLINE) to OFFLINE
2017-10-25 10:41:16.846 [hingStatusInfoChangedEvent] - 'mysensors:ir:gateway:ir_10_1' changed from OFFLINE (BRIDGE_OFFLINE) to OFFLINE
2017-10-25 10:41:16.851 [hingStatusInfoChangedEvent] - 'mysensors:ir:gateway:ir_20_1' changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (BRIDGE_OFFLINE)
2017-10-25 10:41:16.861 [hingStatusInfoChangedEvent] - 'mysensors:ir:gateway:ir_10_1' changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (BRIDGE_OFFLINE)
2017-10-25 10:41:19.887 [hingStatusInfoChangedEvent] - 'mysensors:bridge-ser:gateway' changed from OFFLINE to ONLINE
2017-10-25 10:41:19.896 [hingStatusInfoChangedEvent] - 'mysensors:ir:gateway:ir_20_1' changed from OFFLINE to ONLINE
2017-10-25 10:41:19.905 [hingStatusInfoChangedEvent] - 'mysensors:ir:gateway:ir_10_1' changed from OFFLINE to ONLINE
Can you guys help me out or tell me how to fix it?
Kind regards,
EDIT #1: Added Full stacktrace thanks @namraccr
EDIT #2: @namraccr you are totally right. sorry about it.
EDIT #3: added More detailed description
