Hi Folks
mysql db do not connect to openhab
what am i missing?
018-04-01 16:06:14.012 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
2018-04-01 16:06:14.493 [INFO ] [assic.internal.servlet.WebAppServlet] - Started Classic UI at /classicui/app
2018-04-01 16:06:14.599 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2018-04-01 16:06:14.700 [INFO ] [b.core.service.AbstractActiveService] - Exec Refresh Service has been started
2018-04-01 16:06:17.538 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
2018-04-01 16:06:17.680 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2018-04-01 16:06:18.600 [ERROR] [sql.internal.MysqlPersistenceService] - mySQL: Failed connecting to the SQL database using: driverClass=com.mysql.jdbc.Driver, url=jdbc:mysql://localhost:3306/openhab, user=openhab, password=openhab
com.mysql.jdbc.exceptions.jdbc4.CommunicationsException: Communications link failure
The last packet sent successfully to the server was 0 milliseconds ago. The driver has not received any packets from the server.
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method) ~[?:?]
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62) [?:?]
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45) [?:?]
at java.lang.reflect.Constructor.newInstance(Constructor.java:423) [?:?]
at com.mysql.jdbc.Util.handleNewInstance(Util.java:411) [250:org.openhab.persistence.mysql:1.11.0]
at com.mysql.jdbc.SQLError.createCommunicationsException(SQLError.java:1121) [250:org.openhab.persistence.mysql:1.11.0]
at com.mysql.jdbc.MysqlIO.<init>(MysqlIO.java:357) [250:org.openhab.persistence.mysql:1.11.0]
at com.mysql.jdbc.ConnectionImpl.coreConnect(ConnectionImpl.java:2482) [250:org.openhab.persistence.mysql:1.11.0]
at com.mysql.jdbc.ConnectionImpl.connectOneTryOnly(ConnectionImpl.java:2519) [250:org.openhab.persistence.mysql:1.11.0]
at com.mysql.jdbc.ConnectionImpl.createNewIO(ConnectionImpl.java:2304) [250:org.openhab.persistence.mysql:1.11.0]
at com.mysql.jdbc.ConnectionImpl.<init>(ConnectionImpl.java:834) [250:org.openhab.persistence.mysql:1.11.0]
at com.mysql.jdbc.JDBC4Connection.<init>(JDBC4Connection.java:47) [250:org.openhab.persistence.mysql:1.11.0]
- i have well installed mysql thanks to this guide
- /etc/openhab2/services/mysql.cfg:
############################ mySQL Persistence Service ##################################
# the database url like 'jdbc:mysql://<host>:<port>/<database>'
mysql:url=jdbc:mysql://localhost/openhab
# the database user
mysql:user=openhab
# the database password
mysql:password=openhab
# the reconnection counter
mysql:reconnectCnt=1
# the connection timeout (in seconds)
mysql:waitTimeout=15
# optional tweaking of mysql datatypes
# example as described in https://github.com/openhab/openhab/issues/710
# mysql:sqltype.string=VARCHAR(20000)
# Use MySQL Server time to store item values (=false) or use openHAB Server time (=true).
# For new installations, its recommend to set "mysql:localtime=true".
# (available since 1.9, optional, defaults to false)
#mysql:localtime=true
- /var/lib/openhab2/config/org/openhab/mysql.config which is autogenerated
password="openhab"
reconnectCnt="1"
service.pid="org.openhab.mysql"
url="jdbc:mysql://localhost:3306/openhab"
user="openhab"
i have selected the mysql pertinence
mysql.persist
Strategies {
everyMinute : "0 * * * * ?"
everyHour : "0 0 * * * ?"
everyDay : "0 0 0 * * ?"
default = everyChange
Items {
PersistentValues* : strategy = everyChange, restoreOnStartup
