Some of my items do not get their value’s restored on startup, while (as far as i can see) everything is setup right.
Item definition:
Number verd2_cvruimte_cv_programma "CV programma" (_grpPersist)
Persistence definition:
Strategies {
everyMonth : "0 0 0 1 * ?"
everyDay : "0 0 0 * * ?"
everyHour : "0 0 * * * ?"
everyFiveMinutes : "0 */5 * * * ?"
everyMinute : "0 * * * * ?"
default = everyChange
Items {
_grpPersist* : strategy = restoreOnStartup, everyChange
Sitemap:
Switch item=verd2_cvruimte_cv_programma mappings=[0="Off", 1="On", 2="Tijdl", 3="Auto"]
log file (with debug trace) It shows a value change (Item101) and restart of openHAB
**2018-08-25 12:44:19.062 [DEBUG] [sql.internal.MysqlPersistenceService] - mySQL: Stored item 'verd2_cvruimte_cv_programma' as '2'[2] in SQL database at 2018-08-25 12:44:19.047.**
**2018-08-25 12:44:19.066 [DEBUG] [sql.internal.MysqlPersistenceService] - mySQL: query: INSERT INTO Item101 (TIME, VALUE) VALUES(?,?) ON DUPLICATE KEY UPDATE VALUE=?;**
2018-08-25 12:45:15.415 [INFO ] [basic.internal.servlet.WebAppServlet] - Stopped Basic UI
2018-08-25 12:45:22.314 [DEBUG] [org.openhab.persistence.mysql ] - BundleEvent STOPPING - org.openhab.persistence.mysql
2018-08-25 12:45:22.319 [DEBUG] [org.openhab.persistence.mysql ] - ServiceEvent UNREGISTERING - {org.openhab.core.persistence.PersistenceService}={service.id=371, service.bundleid=215, service.scope=bundle, user=openhab, url=jdbc:mysql://127.0.0.1:3306/openhab, component.name=org.openhab.persistence.mysql, reconnectCnt=1, component.id=249, password=DKtXmbAl1IKF7God, localtime=true, waitTimeout=28800, service.pid=org.openhab.mysql} - org.openhab.persistence.mysql
2018-08-25 12:45:22.336 [DEBUG] [sql.internal.MysqlPersistenceService] - mySQL persistence bundle stopping. Disconnecting from database.
2018-08-25 12:45:22.341 [DEBUG] [sql.internal.MysqlPersistenceService] - mySQL: Disconnected from database jdbc:mysql://127.0.0.1:3306/openhab
2018-08-25 12:45:22.355 [DEBUG] [nal.MysqlPersistenceServiceActivator] - mySQL persistence bundle has been stopped.
2018-08-25 12:45:22.358 [DEBUG] [org.openhab.persistence.mysql ] - BundleEvent STOPPED - org.openhab.persistence.mysql
2018-08-25 12:45:22.588 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Stopped HABmin servlet
2018-08-25 12:45:26.135 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Stopped Paper UI
2018-08-25 12:45:26.169 [INFO ] [panel.internal.HABPanelDashboardTile] - Stopped HABPanel
2018-08-25 12:45:26.193 [INFO ] [.dashboard.internal.DashboardService] - Stopped Dashboard
2018-08-25 12:45:38.988 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2018-08-25 12:45:41.574 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Time zone set to 'Europe/Amsterdam'.
2018-08-25 12:45:41.584 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Location set to '53.191773999999995,6.552160499999999'.
2018-08-25 12:45:41.588 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to 'nl_NL'.
2018-08-25 12:45:41.592 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Measurement system set to 'SIUnits'.
2018-08-25 12:45:53.109 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Verwarming.items'
2018-08-25 12:45:54.121 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'mysql.persist'
2018-08-25 12:45:56.844 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2018-08-25 12:46:37.664 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Verwarming.rules'
2018-08-25 12:46:46.362 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model '_default.sitemap'
2018-08-25 12:46:46.859 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'all.things'
2018-08-25 12:46:51.114 [INFO ] [ternal.dhcp.DHCPPacketListenerServer] - DHCP request packet listener online
2018-08-25 12:46:54.027 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
2018-08-25 12:46:54.235 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2018-08-25 12:47:07.395 [DEBUG] [org.openhab.persistence.mysql ] - BundleEvent STARTING - org.openhab.persistence.mysql
2018-08-25 12:47:07.404 [DEBUG] [nal.MysqlPersistenceServiceActivator] - mySQL persistence bundle has been started.
2018-08-25 12:47:07.406 [DEBUG] [org.openhab.persistence.mysql ] - BundleEvent STARTED - org.openhab.persistence.mysql
2018-08-25 12:47:07.419 [DEBUG] [org.openhab.persistence.mysql ] - ServiceEvent REGISTERED - {org.openhab.core.persistence.PersistenceService}={service.id=371, service.bundleid=215, service.scope=bundle, user=openhab, url=jdbc:mysql://127.0.0.1:3306/openhab, component.name=org.openhab.persistence.mysql, reconnectCnt=1, component.id=249, password=DKtXmbAl1IKF7God, localtime=true, waitTimeout=28800, service.pid=org.openhab.mysql} - org.openhab.persistence.mysql
2018-08-25 12:47:07.436 [DEBUG] [sql.internal.MysqlPersistenceService] - mySQL: Attempting to connect to database jdbc:mysql://127.0.0.1:3306/openhab
2018-08-25 12:47:08.408 [DEBUG] [sql.internal.MysqlPersistenceService] - mySQL: Connected to database jdbc:mysql://127.0.0.1:3306/openhab
2018-08-25 12:47:08.422 [DEBUG] [sql.internal.MysqlPersistenceService] - mySQL: Setting wait_timeout to 28800 seconds.
2018-08-25 12:47:08.437 [DEBUG] [sql.internal.MysqlPersistenceService] - mySQL configuration complete.
**2018-08-25 12:47:08.962 [DEBUG] [sql.internal.MysqlPersistenceService] - mySQL query: item is verd2_cvruimte_cv_programma**
**2018-08-25 12:47:08.965 [DEBUG] [sql.internal.MysqlPersistenceService] - mySQL: query:SELECT Time, Value FROM Item101 ORDER BY Time DESC LIMIT 0,1**
**2018-08-25 12:47:08.972 [DEBUG] [sql.internal.MysqlPersistenceService] - mySQL: query returned 1 rows in 6ms**
2018-08-25 12:47:10.322 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
After the restart the corresponding button (in basicui and in habpanel) is not ‘active’
