Hi!
I upgraded my Raspberry PI today to latest snapshot openHAB 2.2.0 Build #1066 via apt-get. My MySQL-persistence then stopped working, the openhab.log throws:
2017-10-21 23:15:53.488 [ERROR] [org.openhab.persistence.mysql ] - [org.openhab.persistence.mysql(194)] The activate method has thrown an exception
java.lang.IllegalAccessError: tried to access method com.mysql.jdbc.ConnectionImpl.getInstance(Ljava/lang/String;ILjava/util/Properties;Ljava/lang/String;Ljava/lang/String;)Lcom/mysql/jdbc/Connection; fro
m class com.mysql.jdbc.NonRegisteringDriver
at com.mysql.jdbc.NonRegisteringDriver.connect(NonRegisteringDriver.java:346) ~[?:?]
at java.sql.DriverManager.getConnection(DriverManager.java:664) ~[?:?]
at java.sql.DriverManager.getConnection(DriverManager.java:247) ~[?:?]
at org.openhab.persistence.mysql.internal.MysqlPersistenceService.connectToDatabase(MysqlPersistenceService.java:521) ~[?:?]
at org.openhab.persistence.mysql.internal.MysqlPersistenceService.activate(MysqlPersistenceService.java:191) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
2017-10-21 23:15:53.806 [WARN ] [org.openhab.persistence.mysql ] - FrameworkEvent WARNING - org.openhab.persistence.mysql
org.osgi.framework.ServiceException: org.apache.felix.scr.impl.manager.SingleComponentManager.getService() returned a null service object
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:232) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:496) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:619) ~[?:?]
2017-10-21 23:15:53.816 [ERROR] [org.openhab.persistence.mysql ] - [org.openhab.persistence.mysql(194)] The activate method has thrown an exception
java.lang.IllegalAccessError: tried to access method com.mysql.jdbc.ConnectionImpl.getInstance(Ljava/lang/String;ILjava/util/Properties;Ljava/lang/String;Ljava/lang/String;)Lcom/mysql/jdbc/Connection; from class com.mysql.jdbc.NonRegisteringDriver
I’m running MySQL on the same RPI using the following mysql.cfg:
# the database url like 'jdbc:mysql://<host>:<port>/<database>' (without quotes)
url=jdbc:mysql://localhost:3306/OpenHAB
# the database user
user=openhab
# the database password
password=****
# the reconnection counter
#reconnectCnt=
# the connection timeout (in seconds)
#waitTimeout=
# Use MySQL Server time to store item values (=false) or use openHAB Server time (=true).
# For new installations, its recommend to set "localtime=true".
# (optional, defaults to false)
localtime=true
My mysql.persist:
// persistence strategies have a name and a definition and are referred to in the "Items" section
Strategies {
// if no strategy is specified for an item entry below, the default list will be used
everyMinute : "0 * * * * ?"
every5Minutes : "0 */5 * * * ?"
everyHour : "0 0 * * * ?"
everyDay : "0 0 0 * * ?"
default = everyChange
Items {
// persist all items once a day and on every change and restore them from the db at startup
* : strategy = everyChange, everyDay, restoreOnStartup
// additionally, persist all temperature and weather values every five minutes
gTemp*, gHumid*, gRain*, gWind* : strategy = every5Minutes, restoreOnStartup
I’ve not installed the JDBC persistence, but it worked before today’s upgrade.
Any clues on what might be wrong?
BR,
/Janne
