I saw in the forum that I should install HABmin to see if MySQL persistence is working however I don’t see anything shown there when I select MySQL in persistence tab. Here’s what I see:
If that doesn’t work, try to persist only a single item instead of a “*” wildcard. If you are not successful on a single item the problem is somewhere else …
