I cant get this to work …
Nothing gets restored when I restart openhab…
My persistence file:
Strategies {
// if no strategy is specified for an item entry below, the default list will be used
everyMinute : "0 * * * * ?"
every15Minutes : "0 */15 * * * ?"
everyHour : "0 0 * * * ?"
everyDay : "0 0 0 * * ?"
default = everyChange
* Each line in this section defines for which item(s) which strategy(ies) should be applied.
* You can list single items, use "*" for all items or "groupitem*" for all members of a group
* item (excl. the group item itself).
Items {
// persist all items once a day and on every change and restore them from the db at startup
* : strategy = everyChange, everyDay, restoreOnStartup
If I look into the mysql-database I can see that after the restart, new “items” are created as if openhab cant see the old data and continue with it… (and therefore unable to restore it…?)
I use Openhab2 (2.1.0-SNAPSHOT Build #789)
Raspbian (RPI2), mysql on the same box
JDBC Persistence MySQL persistence-jdbc-mysql - 1.10.0.SNAPSHOT
MySQL Persistence persistence-mysql - 1.10.0.SNAPSHOT
Why do I need both by the way ?
This is a perhaps interesting part of the startup in the log:
2017-03-20 22:05:23.151 [INFO ] [ternal.scheduler.WeatherJobScheduler] - Starting and scheduling weatherJob-home with interval of 30 minutes
2017-03-20 22:05:23.858 [ERROR] [org.openhab.persistence.mysql ] - [org.openhab.persistence.mysql(179)] The activate method has thrown an exception
java.lang.IllegalAccessError: tried to access method com.mysql.jdbc.ConnectionImpl.getInstance(Ljava/lang/String;ILjava/util/Properties;Ljava/lang/String;Ljava/lang/String$
at com.mysql.jdbc.NonRegisteringDriver.connect(NonRegisteringDriver.java:346)
at java.sql.DriverManager.getConnection(DriverManager.java:664)[:1.8.0_121]
at java.sql.DriverManager.getConnection(DriverManager.java:247)[:1.8.0_121]
at org.openhab.persistence.mysql.internal.MysqlPersistenceService.connectToDatabase(MysqlPersistenceService.java:521)
at org.openhab.persistence.mysql.internal.MysqlPersistenceService.activate(MysqlPersistenceService.java:190)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)[:1.8.0_121] ........
Than a bit later in the log:
2017-03-20 22:05:24.145 [WARN ] [org.openhab.persistence.mysql ] - FrameworkEvent WARNING - org.openhab.persistence.mysql
org.osgi.framework.ServiceException: org.apache.felix.scr.impl.manager.SingleComponentManager.getService() returned a null service object
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:232)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:496)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:619)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:] ........
Ah! I think that is the culprit: you have two bindings assigned to the same DB and in addition there could be an error in the setup/config!
actually if you only use mysql, you only need the mysql persistence binding.
I personally use MySQL only with mysql binding and it works A-OK.
I would suggest you uninstall the JDBC binding and remove all associated files(jdbc.cfg and jdbc.persistence), configure the mysql binding, wipe the DB clean and restart OH.
one step forward and one back here Now the system actually restores the previous values at restart … great!
But now when I try to access a temperature-graph in my sitemap nothing shows up … and in the log:
2017-03-21 12:41:12.068 [WARN ] [jdbc.internal.JdbcPersistenceService] - JDBC::query: unable to find table for query, no data in database for item 'Temperature'. Current number of tables in the database: 3
2017-03-21 12:41:12.072 [WARN ] [jdbc.internal.JdbcPersistenceService] - JDBC::query: try to generate the table for item 'Temperature'
Is this related to the JDBC/mysql-binding that I removed?
Well 80% ain’t that bad
My guess would be: either the Item “Temperature” has just not been persisted again, or you have directly referenced the JDBC persistence in your chart definition.
Quote from the Docs:
Chart [item=] [icon=""] [label=""] [refresh=xxxx]
[period=xxxx] [service=""] [begin=yyyyMMddHHmm] [end=yyyyMMddHHmm] service sets the persistence service to use. If no service is set, openHAB will use the first queryable persistence service it finds. Therefore, for an installation with only a single persistence service, this is not required.
Problem solved!
I added service=“mysql” to my sitemap item … I read somewhere that you didnt need that if you only had one persistence service… but apparently that wasnt correct in my case…
