After working perfectly for months my one WeMo switch has stopped responding to OpenHab. It works fine with the WeMo app.
OpenHab thinks it is working and reports it “ONLINE” and turning “OFF” and “ON” as expected, but the switch does not switch.
In my troubleshooting I have set up a fresh OpenHab on another Raspberry Pi with one binding (WeMo). That too does not spot the WeMo switch.
I am thinking that it might be the Wemo Switch itself, but when I get OpenHab to search for a Wemo device I see this in openhab.log on my trusty max2play production server (but the test server is totally clean when it searches).
at org.openhab.binding.squeezebox.internal.discovery.SqueezeBoxServerDiscoveryParticipant.getThingUID(SqueezeBoxServerDiscoveryParticipant.java:100) ~[?:?]
at org.openhab.binding.squeezebox.internal.discovery.SqueezeBoxServerDiscoveryParticipant.createResult(SqueezeBoxServerDiscoveryParticipant.java:56) ~[?:?]
at org.eclipse.smarthome.config.discovery.upnp.internal.UpnpDiscoveryService.remoteDeviceAdded(UpnpDiscoveryService.java:198) [200:org.eclipse.smarthome.config.discovery.upnp:0.10.0.oh240]
at org.jupnp.registry.RemoteItems$1.run(RemoteItems.java:114) [205:org.jupnp:2.5.1]
I am on 2.4.0 Release Build, with java version “1.8.0_191”
Java™ SE Runtime Environment (build 1.8.0_191-b12)
Java HotSpot™ Client VM (build 25.191-b12, mixed mode) and I have cleared my cache and rebooted.
I am guessing my question is “Should my next step be buying a new WeMo for testing or another more reliable switch for OpenHab - if so, what?”
