Naming convention and using names in rules (if light switched on -> sendMail)
All,
I´m very new to Openhab2 and Rasperry Pi 3 but made Openhab run, including Mail + Pushover services. I have spent hourse reading on this topic but didn´t find a solution yet.
I am still struggling to create a rule that, upon system reboot, a certain wall plug will be switched.
Imagine one of my items is call:
Fibaro_Wallplug_1 and it appears as such in Paper UI.
The thing is linked with the “switch” functionality, I can copy the following info out of the PaperUI → config → items → “Switch” section: FibaroWallPlugNo1_Switch
I still don´t get the following rule to work:
rule “Light on System boot”
System started
Item=FibaroWallPlugNo1_Switch change status ON
Can you please advise? Even though this rule doesn´t really make sense, it´s super important for me to understand how to include items in a certain rule.
Thanks!
I would advise you to read this: http://docs.openhab.org/configuration/rules-dsl.html carefully..
To send a command to an item, the syntax is <item>.sendCommand(<command>) (without <>)
so for you it would be
    FibaroWallPlugNo1_Switch.sendCommand(ON)
Hi Nicolas,
you made my day, thanks so much!
Kind regards,
dreamerbb
