i finally installed my Nanoleaf Canvas Panels today and got everything working. I can controll all Panels the same time with sending Commands to the controller.
But everytime I send a single Command (like Color or Brightness) to a single Panel, all other Panels gets turned off and only the single Panel gets set to that state.
I want all other Panels stay in the color / light they are, but only set a single panel to another color.
I read in the binding doc, that if you set a dynamic scene for all then set a color to a panel, the dynamic mode gets turned off and switche to static mode resulting in turning off all panels.
Though the same happens if I use a static mode for all panels, then set a color to a single panel, all gets shut down.
Is there something I miss or did not read in the doc?
Thank you very much!
Ricardo
