I just wanted to verify that the NanoMote Quad does not support multilevel function. long presses don’t send a scene and this page seems to confirm that only single presses on the buttons are supported.
Is this true?
Is this true?
I’m actually getting long presses, just have to hold it a bit. But any multi press simply wakes the device.
I wonder if you can adjust the duration in the device configuration?
No, there are very few options in the binding. The wakeup period can’t even be set, although, anytime you press a button, a battery status is sent.
