Natural Binding, Things and links to items discovery
In order to ease items file definitions, did I propose this tools that create a group for each installed binding, containing a group for each thing defined, containing the list of linked items :
 from core.log import logging, LOG_PREFIX, log_traceback
from core.items import add_item, remove_item
from core.utils import validate_item
import requests
import sys
# Modify these variables to fit your system
URL_OPENHAB = "http://localhost:8080"
bindingTag = "BindingDiscovery"
def normalizeBindingId(id):
	id = "g" + id.capitalize()
	return id
def cleanBindingName(name):
	name = name.replace("Binding","").replace("Extensions","").replace("Extension","")
	name = name.strip()
	return name
def normalizeThingId(uid):
	groupname = []
	for element in uid:
		groupname.append(element.capitalize().replace("-","_"))
	groupname[0] = "g"
	return "".join(groupname)
def discoverLinks(log):
	log.info(u"Linked items discovery....")
	links = requests.get(url=URL_OPENHAB + "/rest/links").json()
	count = 0
	for link in links:
		count += 1
		channelUID = link["channelUID"]
		itemName = link["itemName"]
		thingUID = channelUID.split(":")
		del thingUID[-1]
		thingGroupName = normalizeThingId(thingUID)
		group = validate_item(thingGroupName)
		item = validate_item(itemName)
		if group != None and item != None:
			group.addMember(item)
	log.info(u"Discovered {} links.".format(count))
def discoverThings(log):
	log.info(u"Installed things discovery....")
	things = requests.get(url=URL_OPENHAB + "/rest/things").json()
	count = 0
	for thing in things:
		count += 1
		uid = thing["UID"].replace(":"," ").split(" ")
		bindingId = normalizeBindingId(uid[0])
		id = normalizeThingId(uid)
		name = thing["label"]
		add_item(id, item_type="Group", label=name, groups=[bindingId], category=uid[-1], tags=[bindingTag])
	log.info(u"Discovered {} things.".format(count))
def discoverBindings(log):
	log.info(u"Installed bindings discovery.....")
	bindings = requests.get(url=URL_OPENHAB + "/rest/bindings").json()
	count = 0
	for binding in bindings:
		count += 1
		id = normalizeBindingId(binding["id"])
		name = cleanBindingName(binding["name"])
		add_item(id, item_type="Group", label=name, groups=["gBindings"], category=binding["id"], tags=[bindingTag])
	log.info(u"Discovered {} bindings.".format(count))
def scriptLoaded(id):
	log = logging.getLogger("{}.autoDiscovery".format(LOG_PREFIX))
	try:
		log.info("Removing all auto generated groups and items...")
		for item in ir.getItemsByTag(bindingTag):
			remove_item(item)
		log.info("Creating top level group...")
		add_item("gBindings", item_type="Group", label="Installed bindings", groups=["gSystem"], category="api",tags=[bindingTag])
		discoverThings(log)
		discoverLinks(log)
	except:
		log.error(sys.exc_info())
Hope this can help somebody
