Hey Guys, I just got a Broadlink RMpro as a pre Christmas present. and one of the things I want to do with it is control my Fujitsu Halcyon mini-split system.
I’ve been following this thread and I have to say the binding is fantastic:
I got it up and running out of the box without a single issue, which is very rare for me.
The problem is The remote for my mini-split system. When it transmits an ir code, it sends ON + system mode + fan mode + temp set point, All as one IR code. I basically have an IR code for each temp set-point, In each mode, in each fan mode eg a sample of ir commands:
ON,Heat,Temp60,FanAuto
On,Cool,Temp60,FanAuto
ON,Heat,Temp60,FanLow
On,Cool,Temp60,FanLow
ON,Heat,Temp60,FanMed
On,Cool,Temp60,FanMed
ON,Heat,Temp60,FanHigh
On,Cool,Temp60,FanHigh
So that’s 8 different IR codes that could be sent if I change the temp to 60, all of which make the mini-split do a different function.
So I guess what I’m trying to figure out is, what is the best way to have OH figure out which command it should send whenever a change is made?
