Hello, I need help finding styles.min.css on the web page you can access it on
http://openhabianpi:8080/habpanel/vendor/styles.min.css
Can you provide it’s directory? I use SFTP and FTP to access openhab’s files. ![]()
CSS config can be overwritten like explained here:
I am well aware of this, however i need to be overwriting the entire .btn class and anything similar, way easier would be just to edit the file, btw i have already added some custom css to my habpanel it’s not what i’m searching for.
As there are no css files in the source code I guess they are compiled into the binding.
That’s right, the default styles and theme are not user-modifiable (without recompiling a new binding).
You can override .btn and other classes in the additional stylesheet file, use the !important directive in your CSS if necessary.
Oh ok, thank you did that ![]()
