I have read the entire setup process for Windows 7 several times and I have removed all installs, rolled back my windows setup to ensure there were no traces of the install and reinstalled twice and still just get this 404 message when I try to connect through the browser to localhost:8080.
Access Error: 404 – Not Found
Cannot locate document: /
My setup is:
Windows 7
Installed the newest Oracle Java from the link in the documentation
I have added the JAVA_HOME environment variable to point to my java install directory
I have tried to install OH in a couple of different locations, currently at C:\OpenHab
The Karaf window opens and everything seems to load and I get the OpenHab prompt and I can see that the uptime stat increases the longer it runs.
shell:info contents below
Launching the openHAB runtime…
karaf.bat: Ignoring predefined value for KARAF_HOME
__ _____ ____
____ ____ ___ ____ / / / / | / __ )
/ __ / __ / _ / __ / // / /| | / __ |
/ // / // / __/ / / / __ / ___ |/ // /
_/ ./_// /// /// |/_____/
/_/ 2.0.0
Release Build
Hit ‘’ for a list of available commands
and ‘[cmd] --help’ for help on a specific command.
Hit ‘’ or type ‘system:shutdown’ or ‘logout’ to shutdown openHAB.
openhab> shell:info
Karaf
Karaf version 4.0.8
Karaf home D:\Openhab\runtime
Karaf base D:\Openhab\userdata
OSGi Framework org.eclipse.osgi-3.10.101.v20150820-1432
JVM
Java Virtual Machine Java HotSpot™ 64-Bit Server VM version 25.121-b
13
Version 1.8.0_121
Vendor Oracle Corporation
Pid 8524
Uptime 18 hours 43 minutes
Total compile time 37.498 seconds
Threads
Live threads 78
Daemon threads 41
Peak 117
Total started 1054
Memory
Current heap size 73,668 kbytes
Maximum heap size 2,357,248 kbytes
Committed heap size 147,456 kbytes
Pending objects 0
Garbage collector Name = ‘G1 Young Generation’, Collections = 23, Ti
me = 0.293 seconds
Garbage collector Name = ‘G1 Old Generation’, Collections = 0, Time
= 0.000 seconds
Classes
Current classes loaded 11,672
Total classes loaded 11,672
Total classes unloaded 0
Operating system
Name Windows 7 version 6.1
Architecture amd64
Processors 8
openhab>
