milo
(M)
January 26, 2020, 10:14am
1
how do i correctly integrate my door window sensors?
my item file
Switch Z_way_switch_DoorWindowSensor14 "Balkontür [MAP(windowdoorcontact.map):%s]" <door> (group_house_doorwindow){ channel="zwave:device:8ee35c25:node14:sensor_door", channel="mqtt:topic:statusdisplay:balkontuer" [profile="follow"]}
map file:
ON=Offen
OFF=Geschlossen
NULL=unknown
-=unknown
zwave:device:8ee35c25:node14:sensor_door is reporting “Open” “Closed” ??
try to complete your map-File with
Open=Offen
Closed=Geschlossen
milo
(M)
January 26, 2020, 10:24am
3
@fibu-freak switch is still not switching to on or off? But the language is now correct
…sorry, but I have no Zwave-Binding and devices installed. So I can’t help in your case. Maybe @sihui can ?
milo
(M)
January 26, 2020, 10:41am
5
@fibu-freak I simply need to transform somehow “Open” , “Closed” to a switch “ON” and “OFF” but how???
Have you tried Item Type Contact ? Item Types -Docs
sihui
(SiHui)
January 26, 2020, 10:46am
7
milo:
sensor_door
sensor_door
is normally a Contact itemtype, so you should change from Switch to Contact.
…sorry I was a second faster with the same idea
milo
(M)
January 26, 2020, 10:53am
9
@sihui how can I than do a switch follow the open and closed of the contact to on and off?? via rule?
sihui
(SiHui)
January 26, 2020, 10:58am
10
Why would you do that? You can’t send any commands to a door sensor, so no need for on or off.
For a door sensor you should only follow the open/closed state.
milo
(M)
January 26, 2020, 3:39pm
11
@sihui
I directly want to send via MQTT broker “Open” and I have solved this with a switch and follow
or what is better?
sihui
(SiHui)
January 27, 2020, 6:22am
12
milo:
or what is better?
As long as it works it should be okay.
I still have no idea why you are doing it so complicated: a Contact itemtype already gives you OPEN and CLOSED to your zwave and your mqtt channel. No need for any transformation maps.
