I am new in openHAB an z-wave and getting an error.
While trying to get the motion sensor working, I get this in Logfile:
2016-10-07 11:55:44.101 [ERROR] [b.z.i.protocol.ZWaveController] - NODE 21: Restore from config: Error deserialising XML file. com.thoughtworks.xstream.converters.reflection.AbstractReflectionConverter$UnknownFi
eldException: No such field org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveWakeUpCommandClass.isGetSupported
---- Debugging information ----
field : isGetSupported
class : org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveWakeUpCommandClass
required-type : org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveWakeUpCommandClass
converter-type : com.thoughtworks.xstream.converters.reflection.ReflectionConverter
path : /node/supportedCommandClasses/entry[14]/WakeUpCommandClass/isGetSupported
line number : 511
class[1] : java.util.HashMap
converter-type[1] : com.thoughtworks.xstream.converters.collections.MapConverter
class[2] : org.openhab.binding.zwave.internal.protocol.ZWaveNode
version : 1.4.6
2016-10-07 11:55:45.146 [ERROR] [z.i.p.i.ZWaveNodeStageAdvancer] - NODE 20: Node advancer: Retries exceeded at DYNAMIC_VALUES
2016-10-07 12:29:09.509 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 21: Unsupported command class ZWAVE_PLUS_INFO
2016-10-07 12:29:09.514 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 21: Unsupported command class DEVICE_RESET_LOCALLY
2016-10-07 12:29:09.516 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 21: Unsupported command class ASSOCIATION_GROUP_INFO
2016-10-07 12:29:09.521 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 21: Unsupported command class POWERLEVEL
2016-10-07 12:29:09.528 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 21: Unsupported command class MULTI_INSTANCE_ASSOCIATION
2016-10-07 12:29:09.535 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 21: Unsupported command class SECURITY
2016-10-07 12:29:09.538 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 21: Unsupported command class FIRMWARE_UPDATE_MD
2016-10-07 12:29:19.403 [ERROR] [WaveController$ZWaveSendThread] - NODE 21: Timeout while sending message. Requeueing - 2 attempts left!
2016-10-07 12:29:19.516 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 21: Unsupported command class ZWAVE_PLUS_INFO
2016-10-07 12:29:19.520 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 21: Unsupported command class DEVICE_RESET_LOCALLY
2016-10-07 12:29:19.523 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 21: Unsupported command class ASSOCIATION_GROUP_INFO
2016-10-07 12:29:19.525 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 21: Unsupported command class POWERLEVEL
2016-10-07 12:29:19.528 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 21: Unsupported command class MULTI_INSTANCE_ASSOCIATION
2016-10-07 12:29:19.537 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 21: Unsupported command class SECURITY
2016-10-07 12:29:19.539 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 21: Unsupported command class FIRMWARE_UPDATE_MD
2016-10-07 12:29:19.886 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 21: Unsupported command class ZWAVE_PLUS_INFO
2016-10-07 12:29:19.889 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 21: Unsupported command class DEVICE_RESET_LOCALLY
2016-10-07 12:29:19.890 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 21: Unsupported command class ASSOCIATION_GROUP_INFO
2016-10-07 12:29:19.892 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 21: Unsupported command class POWERLEVEL
2016-10-07 12:29:19.896 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 21: Unsupported command class MULTI_INSTANCE_ASSOCIATION
2016-10-07 12:29:19.900 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 21: Unsupported command class SECURITY
2016-10-07 12:29:19.901 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 21: Unsupported command class FIRMWARE_UPDATE_MD
2016-10-07 12:29:24.923 [ERROR] [WaveController$ZWaveSendThread] - NODE 21: Timeout while sending message. Requeueing - 1 attempts left!
2016-10-07 12:29:25.047 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 21: Unsupported command class ZWAVE_PLUS_INFO
2016-10-07 12:29:25.050 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 21: Unsupported command class DEVICE_RESET_LOCALLY
2016-10-07 12:29:25.051 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 21: Unsupported command class ASSOCIATION_GROUP_INFO
2016-10-07 12:29:25.053 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 21: Unsupported command class POWERLEVEL
2016-10-07 12:29:25.058 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 21: Unsupported command class MULTI_INSTANCE_ASSOCIATION
2016-10-07 12:29:25.061 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 21: Unsupported command class SECURITY
2016-10-07 12:29:25.063 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 21: Unsupported command class FIRMWARE_UPDATE_MD
2016-10-07 12:29:30.083 [ERROR] [WaveController$ZWaveSendThread] - NODE 21: Timeout while sending message. Requeueing - 2 attempts left!
2016-10-07 14:29:28.933 [ERROR] [WaveController$ZWaveSendThread] - NODE 21: Timeout while sending message. Requeueing - 2 attempts left!
My binding is:
Number Motion_Living_Motion "Bewegungsmelder [MAP(contact.map):%s]" <present> (Test) { zwave="21:0:command=sensor_binary" }
Number Motion_Living_Alarm "Alarmstatus [MAP(contact.map):%s]" <fire> (Test) { zwave="21:0:command=sensor_alarm,alarm_type=0" }
Number Motion_Living_Lux "Lichtstärke: [%.2f Lux]" <sun> (Test) { zwave="21:0:command=sensor_multilevel,sensor_type=3,refresh_interval=30" }
Number Motion_living_Temperature "Temperatur: [%.2f °C]" <temperature> (Test) { zwave="21:0:command=sensor_multilevel,sensor_type=1" }
Number Motion_living_seismic "Seismic: [%.1f]" (Test) {zwave="21:command=sensor_multilevel,sensor_type=25"}
Number Motion_Living_Battery "Batterie [%d %%]" <battery> (Test) { zwave="21:0:command=battery" }
My setup is an Raspberry2 with razberry modul. Other z-wave devices are working fine.
Thanks,
Christoph
