Hi, guys!
I am struggling a little with the setup of my FGW-14. Everything works fine, but OpenHab does not recieve status updates, when the actuators change their state from outside of OpenHab. However, switching the actuators inside OpenHab works very well!
The worst thing: I definateley had this running some days ago! But somehow i messed up and cant find the problem myself (trying and reading for days now…).
My Setup:
Raspi → USB on FGW14-USB → FAM14 with FSRs and FSBs.
In PCT14 the FGW is green and has an Enocean Adress. Same for all actuators.
What i do:
Adding the FGW14 as a thing.
UID: enocean:bridge:4632083bac
label: FGW-14 Gateway
thingTypeUID: enocean:bridge
configuration:
rs485BaseId: 0000B000
path: /dev/ttyUSB0
rs485: true
enableSmack: false
espVersion: ESP2
sendTeachOuts: false
Then adding a thing “Switching and dimming actuator” from the list.
UID: enocean:centralCommand:4632083bac:19f898d631
label: Switching/Dimming Actuator
thingTypeUID: enocean:centralCommand
configuration:
enoceanId: "00000020"
senderIdOffset: 6
suppressRepeating: false
sendingEEPId: A5_38_08_01
receivingEEPId: F6_00_00
broadcastMessages: true
bridgeUID: enocean:bridge:4632083bac
After this i add a teach-in channel and a switch channel (light). I put my actuator (FSR14) on channel 4 (i.e.), mode is 0, and then “LRN”. I press the teach-in button and put the actuator back into auto-Mode. Everything works fine, i can switch it from OH. However, OH does not recieve status-updates ;(
FAM is on Mode 7, i tried every other modes. FGW-14 is on Mode 6.
Can anybody help me? Thank you
