Hi everybody,
Hoping to get some help on this matter. I have a new model FGBS 001 connected to my ZWave network. I have the temperature and lux sensors working properly but I cannot get the motion sensor or alarm to work reliably.
I have my items bound to the items with:
Switch Fibsensor_Alarm “Alarm: [%s]” { zwave=“8:command=sensor_alarm,respond_to_basic=true” }
Here’s what the logs show:
:52.013 [Thread-52] DEBUG o.o.b.z.i.p.s.ApplicationCommandMessageClass - NODE 8: Application Command Request (ALIVE:DONE)
19:59:52.013 [Thread-52] DEBUG o.o.b.z.i.p.s.ApplicationCommandMessageClass - NODE 8: Incoming command class CRC_16_ENCAP
19:59:52.013 [Thread-52] DEBUG o.o.b.z.i.p.c.ZWaveCRC16EncapsulationCommandClass - NODE 8: Received CRC 16 Encapsulation Request
19:59:52.013 [Thread-52] DEBUG o.o.b.z.i.p.c.ZWaveCRC16EncapsulationCommandClass - NODE 8: Calling handleApplicationCommandRequest.
19:59:52.013 [Thread-52] DEBUG o.o.b.z.i.p.c.ZWaveAlarmCommandClass - NODE 8: Received Alarm Request
19:59:52.013 [Thread-52] DEBUG o.o.b.z.i.p.c.ZWaveAlarmCommandClass - NODE 8: Alarm report - Value = 0
19:59:52.013 [Thread-52] DEBUG o.o.b.z.i.p.c.ZWaveAlarmCommandClass - NODE 8: Alarm Type = General (0)
19:59:52.013 [Thread-52] DEBUG o.o.b.z.i.protocol.ZWaveController - Notifying event listeners: ZWaveAlarmValueEvent
19:59:52.013 [Thread-52] DEBUG o.o.b.z.internal.ZWaveActiveBinding - ZwaveIncomingEvent
19:59:52.013 [Thread-52] DEBUG o.o.b.z.internal.ZWaveActiveBinding - NODE 8: Got a value event from Z-Wave network, endpoint = 0, command class = ALARM, value = 0
19:59:52.013 [Thread-52] DEBUG o.o.b.z.i.p.s.ZWaveCommandProcessor - Sent message Message: class = SendData (0x13), type = Request (0x00), payload = 08 02 84 08
19:59:52.013 [Thread-52] DEBUG o.o.b.z.i.p.s.ZWaveCommandProcessor - Recv message Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 08 0D 56 01 71 05 00 00 00 FF 07 08 00 E8 89
19:59:52.013 [Thread-52] DEBUG o.o.b.z.i.p.s.ZWaveCommandProcessor - Checking transaction complete: class=ApplicationCommandHandler, expected=SendData, cancelled=false
I am able to read the events in the debug and see them firing; however, the item is always set to a value of “0” even in the updates. I’ve tried without the “respond_to_basic” and OpenHab throws an error when the zwave event is triggered.
Further, the ‘alarm’ event seems to trigger more reliably than motion detection and I’ve disabled tamper detection / removed association group 2 to reduce false positives on the g-sensor because I live in a condo building. Unfortunately, for both motion sensing and alarm, I run into the same problems though where the item is always set to a value of 0. As a result of the value never changing, my rules don’t trigger properly for when the item receives an update (defeating the whole point of the sensor).
