Need help with JS script and a curl command
I try since a lot of time to translate this curl command into a JS rule code
Here is the curl command
curl -X GET "http://myapi:8080/api/auth" \
 -H "accept: application/json"
How does this curl command look like in a JS rule syntax?
here is my try
const http = require('http')
const options = {
    method: 'GET',
    hostname: 'http://myapi:8080/api',
    port: null,
    path: '/auth',
    headers: {accept: application/json},
const req = http.request(options, function (res) {
    const chunks = []
    res.on('data', function (chunk) {
        chunks.push(chunk)
    res.on('end', function () {
        const body = Buffer.concat(chunks)
        console.log(body.toString())
req.end()
getting this error
Failed to execute rule test: TypeError: Cannot load CommonJS module
Thanks for the hint :slight_smile:
GraalVM is a Node.js like environment but it is not 100% a Node.js environment. Not everything that exists in Node.js is available, notably the http.
But that’s what the sendHttp Rule Actions are for.
Note, if this is a UI Script Action, you cannot have const and let in the top level context of the action. The script gets reused from one run to the next and as a result the second time the rule runs it will complain that it “cannot redefine const options” (for example).
var results = actions.sendHttpGetRequest('http://myapi:8080/api/auth', {"accept": "application/json"}, 5000);
console.log(results);
I’m not 100% I defined the header’s Map right but you get the point.
You also have the option to use the HTTP Binding instead of a rule.
getting this error now
Failed to execute action: 1(Error: Failed to execute rule test: TypeError: (intermediate value).sendHttpGetRequest is not a function: TypeError: (intermediate value).sendHttpGetRequest is not a function
Typo on my part. See the JS Scripting docs for details.
... actions.HTTP.sendHttpGetRequest(...
