so my coding skils are not very good.
I made this little rule for color fade a LED-Strip. It works in general, but it cant exit the loop. It fades the color till restart of OH. You got a solution for this?
Also, is there a better solution for this whole HSB thing?
Wohnzimmer_LED_fade_switch is just a virtual item
rule "Wohnzimmer_LED_fade"
Item Wohnzimmer_LED_fade_switch received update ON
var h = 0
var s = 100
var b = 100
var boolean swstate = true
var hsb = h + "," + s + "," + b
do {
if (Wohnzimmer_LED_fade_switch.state==OFF){
swstate = false
sendCommand(LED_Stripe_Kueche_Color,hsb)
if (h > 359){
h = 0
h = h + 1
Thread::sleep(10)
} while(swstate)
var h = 0
var s = 100
var b = 100
do {
if (h > 359){
h = 0
h = h + 1
Thread::sleep(10)
} while(Wohnzimmer_LED_fade_switch.state==ON)
Not sure if I understand your rule, but to me it looks like Wohnzimmer_LED_fade_switch.state
never changes in your loop; the only changing variable in your loop is h, it ramps up h until h>359, then it resets h to 0, and on and on.
Under what condition would you like to end your loop? when h receives a final value; given that your rule triggers when the item recieved an update on, would this work
do {
h = h + 1
Thread::sleep(10)
} while(h<359)
this would exit the loop when h reaches 359…not sure if this is what you want though…
var h = 0
var s = 100
var b = 100
while(Wohnzimmer_LED_fade_switch.state==ON) {
if (h > 359){
h = 0
h = h + 1
Thread::sleep(10)
