Need Help with Zoomable Camera Image in f7-popup
Problem Description:
I’m working on a multi-camera widget with a fullscreen popup feature. The popup works perfectly, but I need the camera image to be zoomable (pinch-to-zoom) while maintaining automatic refresh.
Current Working Code:
# Current f7-popup implementation (works but NOT zoomable)
- component: f7-popup
    backdrop: true
    closeByBackdropClick: true
    closeByOutsideClick: true
    closeOnEscape: true
    opened: =vars.fullscreenOpen === 'true'
    style:
      background: black
      z-index: 10000
  slots:
    default:
      - component: f7-block
          style:
            align-items: center
            background: black
            display: flex
            height: 100vh
            justify-content: center
            margin: 0
            padding: 0
            position: relative
            width: 100vw
        slots:
          default:
            - component: oh-image-card
                item: "= vars.activeCamera === 1 || vars.activeCamera === undefined ?
                  props.camera1ImageItem : vars.activeCamera === 2 ?
                  props.camera2ImageItem : vars.activeCamera === 3 ?
                  props.camera3ImageItem : vars.activeCamera === 4 ?
                  props.camera4ImageItem : vars.activeCamera === 5 ?
                  props.camera5ImageItem : vars.activeCamera === 6 ?
                  props.camera6ImageItem : vars.activeCamera === 7 ?
                  props.camera7ImageItem : props.camera1ImageItem"
                noBorder: true
                noShadow: true
                refreshInterval: =props.refreshRate
                style:
                  background: transparent
                  height: 100%
                  object-fit: contain
                  width: 100%
            - component: oh-button
                action: variable
                actionVariable: fullscreenOpen
                actionVariableValue: "false"
                iconColor: red
                iconF7: xmark
                iconSize: 28
                style:
                  position: absolute
                  right: 0px
                  top: 0px
                  z-index: 10001
What I’ve Tried:
Attempt 1: Using f7-photo-browser with action: photos
# This approach makes image zoomable but NO refresh functionality
    action: photos
    actionPhotos:
      - "=items[vars.activeCamera === 1 ? props.camera1ImageItem :
           vars.activeCamera === 2 ? props.camera2ImageItem :
           props.camera1ImageItem].state"
    style:
      # button styles...
Result: :white_check_mark: Image is zoomable, :cross_mark: No automatic refresh (static image)
Attempt 2: Using f7-photo-browser component directly
# Tried embedding f7-photo-browser in popup
- component: f7-photo-browser
    photos:
      - "=items[props.camera1ImageItem].state"
    type: popup
    # other configs...
Result: :cross_mark: Doesn’t work as expected in widget context
Attempt 3: CSS transform for zoom
# Tried adding CSS transforms to oh-image-card
style:
  transform-origin: center
  transition: transform 0.3s ease
  # touch events don't work properly
Result: :cross_mark: No proper touch/pinch zoom support
Requirements:
  1. :white_check_mark: Zoomable image (pinch-to-zoom, pan when zoomed)
  2. :white_check_mark: Automatic refresh (e.g., every 1000ms)
  3. :white_check_mark: Fullscreen popup overlay
  4. :white_check_mark: Close button functionality
  5. :white_check_mark: Dynamic camera switching (7 different cameras)
Questions:
  1. Is there a way to make oh-image-card zoomable within f7-popup?
  2. Can f7-photo-browser be configured to auto-refresh images?
  3. Are there alternative approaches using other F7 components?
  4. CSS-only solutions that work with touch devices?
Any suggestions or working examples would be greatly appreciated!
and by the way here is the full actual code:
uid: CameraSnapshotHistory_auto_v3
tags: []
props:
  parameters:
    - label: Kamera 1 Equipment
      required: false
      type: TEXT
    - label: Kamera 1 Name
      required: false
      type: TEXT
    - label: Kamera 1 Base URL
      required: false
      type: TEXT
    - context: item
      label: Kamera 1 Image Item
      required: false
      type: TEXT
    - context: item
      label: Kamera 1 PTZ Preset Item
      required: false
      type: TEXT
    - description: "Format: 1=Option1,2=Option2,3=Option3"
      label: Kamera 1 PTZ Preset Options
      required: false
      type: TEXT
    - context: item
      label: Kamera 1 PTZ Auto Reset Item
      required: false
      type: TEXT
    - description: "Format: 1=Auto-Reset,2=Kamerafahrt,3=Manuell"
      label: Kamera 1 PTZ Auto Reset Options
      required: false
      type: TEXT
    - label: Kamera 2 Equipment
      required: false
      type: TEXT
    - label: Kamera 2 Name
      required: false
      type: TEXT
    - label: Kamera 2 Base URL
      required: false
      type: TEXT
    - context: item
      label: Kamera 2 Image Item
      required: false
      type: TEXT
    - context: item
      label: Kamera 2 PTZ Preset Item
      required: false
      type: TEXT
      label: Kamera 2 PTZ Preset Options
      required: false
      type: TEXT
    - context: item
      label: Kamera 2 PTZ Auto Reset Item
      required: false
      type: TEXT
      label: Kamera 2 PTZ Auto Reset Options
      required: false
      type: TEXT
    - label: Kamera 3 Equipment
      required: false
      type: TEXT
    - label: Kamera 3 Name
      required: false
      type: TEXT
    - label: Kamera 3 Base URL
      required: false
      type: TEXT
    - context: item
      label: Kamera 3 Image Item
      required: false
      type: TEXT
    - context: item
      label: Kamera 3 PTZ Preset Item
      required: false
      type: TEXT
      label: Kamera 3 PTZ Preset Options
      required: false
      type: TEXT
    - context: item
      label: Kamera 3 PTZ Auto Reset Item
      required: false
      type: TEXT
      label: Kamera 3 PTZ Auto Reset Options
      required: false
      type: TEXT
    - label: Kamera 4 Equipment
      required: false
      type: TEXT
    - label: Kamera 4 Name
      required: false
      type: TEXT
    - label: Kamera 4 Base URL
      required: false
      type: TEXT
    - context: item
      label: Kamera 4 Image Item
      required: false
      type: TEXT
    - context: item
      label: Kamera 4 PTZ Preset Item
      required: false
      type: TEXT
      label: Kamera 4 PTZ Preset Options
      required: false
      type: TEXT
    - context: item
      label: Kamera 4 PTZ Auto Reset Item
      required: false
      type: TEXT
      label: Kamera 4 PTZ Auto Reset Options
      required: false
      type: TEXT
    - label: Kamera 5 Equipment
      required: false
      type: TEXT
    - label: Kamera 5 Name
      required: false
      type: TEXT
    - label: Kamera 5 Base URL
      required: false
      type: TEXT
    - context: item
      label: Kamera 5 Image Item
      required: false
      type: TEXT
    - context: item
      label: Kamera 5 PTZ Preset Item
      required: false
      type: TEXT
      label: Kamera 5 PTZ Preset Options
      required: false
      type: TEXT
    - context: item
      label: Kamera 5 PTZ Auto Reset Item
      required: false
      type: TEXT
      label: Kamera 5 PTZ Auto Reset Options
      required: false
      type: TEXT
    - label: Kamera 6 Equipment
      required: false
      type: TEXT
    - label: Kamera 6 Name
      required: false
      type: TEXT
    - label: Kamera 6 Base URL
      required: false
      type: TEXT
    - context: item
      label: Kamera 6 Image Item
      required: false
      type: TEXT
    - context: item
      label: Kamera 6 PTZ Preset Item
      required: false
      type: TEXT
      label: Kamera 6 PTZ Preset Options
      required: false
      type: TEXT
    - context: item
      label: Kamera 6 PTZ Auto Reset Item
      required: false
      type: TEXT
      label: Kamera 6 PTZ Auto Reset Options
      required: false
      type: TEXT
    - label: Kamera 7 Equipment
      required: false
      type: TEXT
    - label: Kamera 7 Name
      required: false
      type: TEXT
    - label: Kamera 7 Base URL
      required: false
      type: TEXT
    - context: item
      label: Kamera 7 Image Item
      required: false
      type: TEXT
    - context: item
      label: Kamera 7 PTZ Preset Item
      required: false
      type: TEXT
      label: Kamera 7 PTZ Preset Options
      required: false
      type: TEXT
    - context: item
      label: Kamera 7 PTZ Auto Reset Item
      required: false
      type: TEXT
      label: Kamera 7 PTZ Auto Reset Options
      required: false
      type: TEXT
    - description: Refresh rate in milliseconds (e.g., 1000 for 1 second)
      label: Refresh Rate
      required: true
      type: INTEGER
timestamp: Aug 11, 2025, 1:29:04 PM
component: f7-card
  key: "=((vars.selected || 0) === undefined) ? Math.random() : Math.random() +
    (vars.selected || 0)"
  noBorder: true
  noShadow: true
  style:
    --f7-card-margin-horizontal: 5px
    --f7-card-margin-vertical: 5px
    background: var(--f7-theme-color)
    height: auto
    max-height: "=vars.ptzExpanded === 'true' && vars.archive !== 2 ? 'none' : 'auto'"
    overflow: hidden
    transition: all 0.3s ease
    width: auto
slots:
  default:
        style:
          border-radius: 0px
          color: "=(themeOptions.dark == 'dark') ? 'white' : 'black'"
          margin: 0
          padding: 8px
      slots:
        default:
          - component: f7-swiper
              params:
                direction: horizontal
                freeMode: true
                mousewheel: true
                scrollbar:
                  draggable: true
                  el: .swiper-scrollbar
                slidesPerView: auto
              style:
                height: 40px
            slots:
              default:
                - component: f7-swiper-slide
                    style:
                      padding: 0 4px
                      width: auto
                    visible: =!!(props.camera1 && props.camera1Name)
                  slots:
                    default:
                          action: variable
                          actionVariable: activeCamera
                          actionVariableValue: 1
                          style:
                            align-items: center
                            background: "=vars.activeCamera === 1 || vars.activeCamera === undefined ?
                              'var(--f7-theme-color-shade)' :
                              'rgba(255,255,255,0.2)'"
                            border: "=vars.activeCamera === 1 || vars.activeCamera === undefined ? '2px
                              solid white' : '1px solid rgba(255,255,255,0.3)'"
                            border-radius: 6px
                            color: white
                            display: flex
                            font-size: 13px
                            font-weight: "=vars.activeCamera === 1 || vars.activeCamera === undefined ?
                              'bold' : 'normal'"
                            padding: 4px 8px
                            text-align: center
                          text: =props.camera1Name
                    style:
                      padding: 0 4px
                      width: auto
                    visible: =!!(props.camera2 && props.camera2Name)
                  slots:
                    default:
                          action: variable
                          actionVariableValue: 2
                          style:
                            align-items: center
                            background: "=vars.activeCamera === 2 ? 'var(--f7-theme-color-shade)' :
                            border: "=vars.activeCamera === 2 ? '2px solid white' : '1px solid
                            border-radius: 6px
                            color: white
                            display: flex
                            font-size: 13px
                            font-weight: "=vars.activeCamera === 2 ? 'bold' : 'normal'"
                            padding: 4px 8px
                            text-align: center
                          text: =props.camera2Name
                    style:
                      padding: 0 4px
                      width: auto
                    visible: =!!(props.camera3 && props.camera3Name)
                  slots:
                    default:
                          action: variable
                          actionVariableValue: 3
                          style:
                            align-items: center
                            background: "=vars.activeCamera === 3 ? 'var(--f7-theme-color-shade)' :
                            border: "=vars.activeCamera === 3 ? '2px solid white' : '1px solid
                            border-radius: 6px
                            color: white
                            display: flex
                            font-size: 13px
                            font-weight: "=vars.activeCamera === 3 ? 'bold' : 'normal'"
                            padding: 4px 8px
                            text-align: center
                          text: =props.camera3Name
                    style:
                      padding: 0 4px
                      width: auto
                    visible: =!!(props.camera4 && props.camera4Name)
                  slots:
                    default:
                          action: variable
                          actionVariableValue: 4
                          style:
                            align-items: center
                            background: "=vars.activeCamera === 4 ? 'var(--f7-theme-color-shade)' :
                            border: "=vars.activeCamera === 4 ? '2px solid white' : '1px solid
                            border-radius: 6px
                            color: white
                            display: flex
                            font-size: 13px
                            font-weight: "=vars.activeCamera === 4 ? 'bold' : 'normal'"
                            padding: 4px 8px
                            text-align: center
                          text: =props.camera4Name
                    style:
                      padding: 0 4px
                      width: auto
                    visible: =!!(props.camera5 && props.camera5Name)
                  slots:
                    default:
                          action: variable
                          actionVariableValue: 5
                          style:
                            align-items: center
                            background: "=vars.activeCamera === 5 ? 'var(--f7-theme-color-shade)' :
                            border: "=vars.activeCamera === 5 ? '2px solid white' : '1px solid
                            border-radius: 6px
                            color: white
                            display: flex
                            font-size: 13px
                            font-weight: "=vars.activeCamera === 5 ? 'bold' : 'normal'"
                            padding: 4px 8px
                            text-align: center
                          text: =props.camera5Name
                    style:
                      padding: 0 4px
                      width: auto
                    visible: =!!(props.camera6 && props.camera6Name)
                  slots:
                    default:
                          action: variable
                          actionVariableValue: 6
                          style:
                            align-items: center
                            background: "=vars.activeCamera === 6 ? 'var(--f7-theme-color-shade)' :
                            border: "=vars.activeCamera === 6 ? '2px solid white' : '1px solid
                            border-radius: 6px
                            color: white
                            display: flex
                            font-size: 13px
                            font-weight: "=vars.activeCamera === 6 ? 'bold' : 'normal'"
                            padding: 4px 8px
                            text-align: center
                          text: =props.camera6Name
                    style:
                      padding: 0 4px
                      width: auto
                    visible: =!!(props.camera7 && props.camera7Name)
                  slots:
                    default:
                          action: variable
                          actionVariableValue: 7
                          style:
                            align-items: center
                            background: "=vars.activeCamera === 7 ? 'var(--f7-theme-color-shade)' :
                            border: "=vars.activeCamera === 7 ? '2px solid white' : '1px solid
                            border-radius: 6px
                            color: white
                            display: flex
                            font-size: 13px
                            font-weight: "=vars.activeCamera === 7 ? 'bold' : 'normal'"
                            padding: 4px 8px
                            text-align: center
                          text: =props.camera7Name
        style:
          margin: 0
          overflow: hidden
          padding: 0
          position: relative
      slots:
        default:
          - component: oh-video-card
              hideControls: false
              noBorder: true
              noShadow: true
              startManually: false
              style:
                border-radius: 0px
                display: block
                height: auto
                margin: 0px
                max-width: 100%
                object-fit: contain
                padding: 0px
                width: 100%
              url: "= (vars.activeCamera === 1 || vars.activeCamera === undefined ?
                props.camera1BaseURL : vars.activeCamera === 2 ?
                props.camera2BaseURL : vars.activeCamera === 3 ?
                props.camera3BaseURL : vars.activeCamera === 4 ?
                props.camera4BaseURL : vars.activeCamera === 5 ?
                props.camera5BaseURL : vars.activeCamera === 6 ?
                props.camera6BaseURL : vars.activeCamera === 7 ?
                props.camera7BaseURL : props.camera1BaseURL) +
                items[(vars.activeCamera === 1 || vars.activeCamera ===
                undefined ? props.camera1 : vars.activeCamera === 2 ?
                props.camera2 : vars.activeCamera === 3 ? props.camera3 :
                vars.activeCamera === 4 ? props.camera4 : vars.activeCamera ===
                5 ? props.camera5 : vars.activeCamera === 6 ? props.camera6 :
                vars.activeCamera === 7 ? props.camera7 : props.camera1) +
                '_MP4_History'].state.split(',')[(vars.selected || 0)] + '.mp4'"
              visible: =vars.archive == 2
              noBorder: true
              noShadow: true
              refreshInterval: "=vars.fullscreenOpen === 'true' ? 0 : props.refreshRate"
              style:
                border-radius: 0px
                display: block
                height: auto
                margin: 0px
                max-width: 100%
                object-fit: contain
                padding: 0px
                width: 100%
              visible: =vars.archive != 2
          - component: f7-row
              class: no-gap
              noBorder: true
              noShadow: true
              style:
                height: auto
                position: absolute
                top: 0px
                width: 100%
                z-index: 2
            slots:
              default:
                    action: variable
                    actionVariable: archive
                    iconColor: red
                    iconF7: folder
                    iconSize: 28
                    style:
                      margin: -2px
                    visible: "= items[(vars.activeCamera === 1 || vars.activeCamera === undefined ?
                      props.camera1 : vars.activeCamera === 2 ? props.camera2 :
                      vars.activeCamera === 5 ? props.camera5 :
                      '_MP4_History'].state !== NULL && items[(vars.activeCamera
                      === 1 || vars.activeCamera === undefined ? props.camera1 :
                      '_MP4_History_Length'].state > 0 ? vars.archive !== 2 :
                      false"
                    z-index: 2
                    action: variable
                    actionVariableValue: "true"
                    iconColor: red
                    iconF7: viewfinder
                    iconSize: 28
                    style:
                      height: 32px
                      margin: -2px
                      position: absolute
                      right: 0px
                      top: 0px
                      width: 32px
                      z-index: 2
                    visible: =vars.archive !== 2
                - component: Label
                    style:
                      color: red
                      font-size: 9px
                      left: 14px
                      position: absolute
                      top: 6px
                      z-index: -1
                    text: =((vars.selected || 0)+1)
                    action: variable
                    iconColor: red
                    iconF7: videocam
                    iconSize: 28
                    style:
                      margin: -2px
                    visible: =(vars.archive == 2)
                    action: variable
                    actionVariable: selected
                    actionVariableValue: "= items[(vars.activeCamera === 1 || vars.activeCamera ===
                      '_MP4_History_Length'].state - 1"
                    iconColor: red
                    iconF7: backward_end
                    iconSize: 28
                    style:
                      margin: -2px
                    visible: "=vars.archive == 2 && items[(vars.activeCamera === 1 ||
                      '_MP4_History_Length'].state > 0"
                    action: variable
                    actionVariableValue: "=((vars.selected || 0)+1 < items[(vars.activeCamera === 1
                      '_MP4_History_Length'].state)?((vars.selected || 0)+1):(
                      '_MP4_History_Length'].state-1)"
                    iconColor: red
                    iconF7: arrowtriangle_left
                    iconSize: 28
                    style:
                      margin: -2px
                    action: variable
                    actionVariableValue: =((vars.selected || 0) != 0)?((vars.selected || 0)-1):(0)
                    iconColor: red
                    iconF7: arrowtriangle_right
                    iconSize: 28
                    style:
                      margin: -2px
                    action: variable
                    actionVariableValue: 0
                    iconColor: red
                    iconF7: forward_end
                    iconSize: 28
                    style:
                      margin: -2px
                - component: f7-badge
                    color: red
                    style:
                      border-radius: 50%
                      height: 20px
                      left: 50%
                      position: absolute
                      top: 5px
                      transform: translateX(-50%)
                      width: 12px
                      z-index: 3
                      '_MP4_Recording'].state !== NULL &&
                      '_MP4_Recording'].state > 0 && vars.archive !== 2"
        style:
          border-radius: 0px
          margin: 0
          padding: 8px 15px 15px 15px
          position: relative
        visible: =vars.archive !== 2 && ((vars.activeCamera === 1 || vars.activeCamera
          === undefined) && (!!props.camera1PtzPresetItem ||
          !!props.camera1PtzAutoResetItem) || vars.activeCamera === 2 &&
          (!!props.camera2PtzPresetItem || !!props.camera2PtzAutoResetItem) ||
          vars.activeCamera === 3 && (!!props.camera3PtzPresetItem ||
          !!props.camera3PtzAutoResetItem) || vars.activeCamera === 4 &&
          (!!props.camera4PtzPresetItem || !!props.camera4PtzAutoResetItem) ||
          vars.activeCamera === 5 && (!!props.camera5PtzPresetItem ||
          !!props.camera5PtzAutoResetItem) || vars.activeCamera === 6 &&
          (!!props.camera6PtzPresetItem || !!props.camera6PtzAutoResetItem) ||
          vars.activeCamera === 7 && (!!props.camera7PtzPresetItem ||
          !!props.camera7PtzAutoResetItem))
      slots:
        default:
          - component: f7-row
              style:
                align-items: center
                height: 40px
                margin-bottom: 5px
            slots:
              default:
                    action: variable
                    actionVariable: ptzExpanded
                    actionVariableValue: "=vars.ptzExpanded === 'true' ? 'false' : 'true'"
                    style:
                      --f7-button-bg-color: rgba(255,255,255,0.2)
                      --f7-button-border-radius: 50%
                      --f7-button-height: 30px
                      --f7-button-width: 30px
                      align-items: center
                      border: 1px solid rgba(255,255,255,0.3)
                      display: flex
                  slots:
                    default:
                      - component: f7-icon
                          f7: "=vars.ptzExpanded === 'true' ? 'chevron_up' : 'chevron_down'"
                          style:
                            color: white
              style:
                height: "=vars.ptzExpanded === 'true' ? 'auto' : '0px'"
                margin-bottom: 10px
                opacity: "=vars.ptzExpanded === 'true' ? '1' : '0'"
                overflow: hidden
              visible: =(vars.activeCamera === 1 || vars.activeCamera === undefined) &&
                !!props.camera1PtzPresetItem || vars.activeCamera === 2 &&
                !!props.camera2PtzPresetItem || vars.activeCamera === 3 &&
                !!props.camera3PtzPresetItem || vars.activeCamera === 4 &&
                !!props.camera4PtzPresetItem || vars.activeCamera === 5 &&
                !!props.camera5PtzPresetItem || vars.activeCamera === 6 &&
                !!props.camera6PtzPresetItem || vars.activeCamera === 7 &&
            slots:
              default:
                - component: Label
                    style:
                      color: white
                      font-size: 13px
                      font-weight: bold
                      margin-bottom: 6px
                    text: "Kamera-Position:"
                    params:
                      freeMode: true
                      mousewheel: true
                      scrollbar:
                        draggable: true
                      slidesPerView: auto
                    style:
                      height: 45px
                  slots:
                    default:
                          style:
                            padding: 0 4px
                            width: auto
                        slots:
                          default:
                                action: command
                                actionCommand: "5"
                                actionItem: "= vars.activeCamera === 1 || vars.activeCamera === undefined ?
                                  props.camera1PtzPresetItem : vars.activeCamera
                                  === 2 ? props.camera2PtzPresetItem :
                                  props.camera3PtzPresetItem : vars.activeCamera
                                  === 4 ? props.camera4PtzPresetItem :
                                  props.camera5PtzPresetItem : vars.activeCamera
                                  === 6 ? props.camera6PtzPresetItem :
                                  props.camera7PtzPresetItem :
                                  props.camera1PtzPresetItem"
                                style:
                                  align-items: center
                                  background: rgba(255,255,255,0.2)
                                  border-radius: 6px
                                  color: white
                                  display: flex
                                  font-size: 12px
                                  font-weight: bold
                                  min-width: 70px
                                  padding: 6px 10px
                                  text-align: center
                                text: Terrasse
                          style:
                            padding: 0 4px
                            width: auto
                        slots:
                          default:
                                action: command
                                actionCommand: "1"
                                style:
                                  align-items: center
                                  border-radius: 6px
                                  color: white
                                  display: flex
                                  font-size: 12px
                                  font-weight: bold
                                  min-width: 70px
                                  padding: 6px 10px
                                  text-align: center
                                text: Garten
                          style:
                            padding: 0 4px
                            width: auto
                        slots:
                          default:
                                action: command
                                actionCommand: "4"
                                style:
                                  align-items: center
                                  border-radius: 6px
                                  color: white
                                  display: flex
                                  font-size: 12px
                                  font-weight: bold
                                  min-width: 70px
                                  padding: 6px 10px
                                  text-align: center
                                text: Gartentür
                          style:
                            padding: 0 4px
                            width: auto
                        slots:
                          default:
                                action: command
                                actionCommand: "3"
                                style:
                                  align-items: center
                                  border-radius: 6px
                                  color: white
                                  display: flex
                                  font-size: 12px
                                  font-weight: bold
                                  min-width: 80px
                                  padding: 6px 10px
                                  text-align: center
                                text: Mähroboter
                          style:
                            padding: 0 4px
                            width: auto
                        slots:
                          default:
                                action: command
                                actionCommand: "6"
                                style:
                                  align-items: center
                                  border-radius: 6px
                                  color: white
                                  display: flex
                                  font-size: 12px
                                  font-weight: bold
                                  min-width: 80px
                                  padding: 6px 10px
                                  text-align: center
                                text: Ahornbeet
                          style:
                            padding: 0 4px
                            width: auto
                        slots:
                          default:
                                action: command
                                actionCommand: "2"
                                style:
                                  align-items: center
                                  border-radius: 6px
                                  color: white
                                  display: flex
                                  font-size: 12px
                                  font-weight: bold
                                  min-width: 70px
                                  padding: 6px 10px
                                  text-align: center
                                text: Freisitz
                          style:
                            padding: 0 4px
                            width: auto
                        slots:
                          default:
                                action: command
                                actionCommand: "7"
                                style:
                                  align-items: center
                                  border-radius: 6px
                                  color: white
                                  display: flex
                                  font-size: 12px
                                  font-weight: bold
                                  min-width: 70px
                                  padding: 6px 10px
                                  text-align: center
                                text: O. Rasen
                          style:
                            padding: 0 4px
                            width: auto
                        slots:
                          default:
                                action: command
                                actionCommand: "8"
                                style:
                                  align-items: center
                                  border-radius: 6px
                                  color: white
                                  display: flex
                                  font-size: 12px
                                  font-weight: bold
                                  min-width: 70px
                                  padding: 6px 10px
                                  text-align: center
                                text: Balkon
                          style:
                            padding: 0 4px
                            width: auto
                        slots:
                          default:
                                action: command
                                actionCommand: "9"
                                style:
                                  align-items: center
                                  border-radius: 6px
                                  color: white
                                  display: flex
                                  font-size: 12px
                                  font-weight: bold
                                  min-width: 110px
                                  padding: 6px 10px
                                  text-align: center
                                text: Haus und Dach
              style:
                overflow: hidden
                !!props.camera1PtzAutoResetItem || vars.activeCamera === 2 &&
                !!props.camera2PtzAutoResetItem || vars.activeCamera === 3 &&
                !!props.camera3PtzAutoResetItem || vars.activeCamera === 4 &&
                !!props.camera4PtzAutoResetItem || vars.activeCamera === 5 &&
                !!props.camera5PtzAutoResetItem || vars.activeCamera === 6 &&
                !!props.camera6PtzAutoResetItem || vars.activeCamera === 7 &&
            slots:
              default:
                - component: Label
                    style:
                      color: white
                      font-size: 13px
                      font-weight: bold
                      margin-bottom: 6px
                    text: "PTZ-Modus:"
                - component: f7-row
                    style:
                      gap: 6px
                  slots:
                    default:
                          action: command
                          actionCommand: "1"
                            props.camera1PtzAutoResetItem : vars.activeCamera
                            === 2 ? props.camera2PtzAutoResetItem :
                            props.camera3PtzAutoResetItem : vars.activeCamera
                            === 4 ? props.camera4PtzAutoResetItem :
                            props.camera5PtzAutoResetItem : vars.activeCamera
                            === 6 ? props.camera6PtzAutoResetItem :
                            props.camera7PtzAutoResetItem :
                            props.camera1PtzAutoResetItem"
                          style:
                            align-items: center
                            border-radius: 6px
                            color: white
                            display: flex
                            flex: 1
                            font-size: 12px
                            font-weight: bold
                            padding: 8px
                            text-align: center
                          text: Auto-Reset
                          action: command
                          actionCommand: "2"
                          style:
                            align-items: center
                            border-radius: 6px
                            color: white
                            display: flex
                            flex: 1
                            font-size: 12px
                            font-weight: bold
                            padding: 8px
                            text-align: center
                          text: Kamerafahrt
                          action: command
                          actionCommand: "3"
                          style:
                            align-items: center
                            border-radius: 6px
                            color: white
                            display: flex
                            flex: 1
                            font-size: 12px
                            font-weight: bold
                            padding: 8px
                            text-align: center
                          text: Manuell
        style:
          border-radius: 0px
          margin: 0
          padding: 8px 15px
        visible: =vars.archive === 2 || !((vars.activeCamera === 1 || vars.activeCamera
      slots:
        default:
          - component: Label
              style:
                display: block
                height: 1px
              text: ""
        backdrop: true
        closeOnEscape: true
        style:
          background: black
          z-index: 10000
      slots:
        default:
              style:
                align-items: center
                background: black
                display: flex
                height: 100vh
                margin: 0
                padding: 0
                position: relative
                width: 100vw
            slots:
              default:
                    noBorder: true
                    noShadow: true
                    style:
                      height: 100%
                      object-fit: contain
                      width: 100%
                    action: variable
                    iconColor: red
                    iconF7: xmark
                    iconSize: 28
                    style:
                      height: 32px
                      margin: -2px
                      position: absolute
                      right: 0px
                      top: 0px
                      width: 32px
                      z-index: 10001
You’re running up against the inherent limitations of the OH widget and f7 systems. I don’t think there’s a built-in way for you to do this. This is probably possible if you are really determined but it will almost definitely require some un-official javascript methods (see this topic).
You certainly cannot easily add the ability to zoom to any widget that does not already have that capability because the setting of the main OH page deactivates basic browser zoom actions. So, it would require significant custom js scripting to add that feature individually to elements.
If there is any remotely reasonable path to this at all, it would be through a simple script that forces the f7 photo browser to refresh the image. You might even able to combine this with something like this so you wouldn’t have worry about creating and destroying your own js timer intervals.
Honestly, if I were trying to create something like this, I would take 1 of 2 paths: 1) Create a quick independent web app that then is just loaded in an oh-webframe (maybe an LLM can even get you most of the way there pretty quickly at this point, I don’t know), or 2) create a PR for the oh webui that adds a refresh interval as a possible configuration to the photos action.
Thanks for the explanation!
I think I’ll go with option 2 and try to create a PR for the OH WebUI to add a refresh interval to the photos action.
I haven’t done a PR before, but I’m willing to give it a try.
Update: I’ve made some changes to add a refresh interval for the photos action, but I don’t have a test environment, so I can’t verify if it works. I would really appreciate it if someone with a working setup could try it and give feedback.
I don’t see your PR on the webui repo. If you have only created a version on your own fork and not submitted it is as a PR yet, then you’ll have to share a link to that fork and branch if others are going to test it for you.
But, even better, you can also submit it as a PR even if it’s not finished. Just label it as [WIP] (work in progress), and then anyone looking at the main repo site will be able to see it and give feedback, including the maintainers who will give you the most valuable feedback (including whether this is a PR that is likely to be approved at all or conflicts with some design goal or UI philosophy - a rare but not impossible occurrence).
Oops — looks like I messed this up a bit — my first PR attempt :sweat_smile:
I originally had the changes split into my own fork’s branches (patch-1 and patch-2) and hadn’t opened a PR. But I’ve now merged everything into a single branch and created a proper [WIP] Pull Request here:
https://github.com/openhab/openhab-webui/pull/3332
Would you mind taking another look now? I’d really appreciate any feedback — especially since I don’t yet have a test environment and the maintainers’ input will be especially valuable.
Thanks in advance!
