I need some help to read my energy meter
I have following thing
Thing exec:command:zaehler [command="cat /dev/ttyUSB0 | xxd -l204 >z1.txt", interval=15, timeout=5, autorun=false]
The energy meter is on the USB 0. If I use the same command on the console the file z1.txt will be stroaged.
On openhab I get an error
2018-11-29 21:58:41.167 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'zaehler.things'
2018-11-29 21:58:41.239 [me.event.ThingUpdatedEvent] - Thing 'exec:command:zaehler' has been updated.
2018-11-29 21:58:41.261 [vent.ItemStateChangedEvent] - Zaehler_strom changed from We trust you have received the usual lecture from the local System
Administrator. It usually boils down to these three things:
#1) Respect the privacy of others.
#2) Think before you type.
#3) With great power comes great responsibility.
sudo: no tty present and no askpass program specified
sudo: no tty present and no askpass program specified to cat: invalid option -- 'l'
Try 'cat --help' for more information.
I can not understand what’s wrong ?!
