I just saw the same thing. You must have a newer version of that switch. I’ve found someone with a similar problem and solution.https://community.openhab.org/t/3-gang-in-wall-switch-gr-b3-3-not-fully-discovered-by-the-binding/36985 Take a look and see if that helps.
