rafa
(Rafa)
1
I receive this message:
in/F_Garage_Door_Closed/state OPEN
And I have this item:
Contact Garage_Contact “Garage Contact” (gGarage) [“GarageDoor”] {channel=“mqtt:topic:Garag_Contact:Garage_Contact_Opened”}
Is there any way to show the negative? I mean, if I receive OPEN, contact item shows CLOSED?
rlkoshak
(Rich Koshak)
2
You can use a proxy Item.
You can use the visibility tag and show a static version of the Item on the sitemap based on the state of the Contact.
You can use a transformation or use a “Custom ON/OPEN value” and “Custom OFF/CLOSED value” on the MQTT Thing.
If you are not using dynamic icons, you can just use a MAP transform in your label.
