Setting it to 99 doesn’t help. The lux level is correct in the sense that I do see the LED on the device flashing, so it’s definitely responding to my movement.
I can certainly changing the association. Is that something I can do in habmin? Do I simply need to set the association for group 2 to ‘Controller’ and leave the other association groups empty?
No, as I mentioned, it sometimes goes back from ALARM to OK but not always.
Meh, I’m giving up, I’ve spent too much of my weekend on this I’ll see if I can also figure out a way to extend the Z-Wave signal, maybe it’s just dropping packets or something.
I’m stopping for today. I think we have the same problems with the NEO coolcam. I had no problems with Domoticz, but i had serious other problems with Domoticz and was trying to move to OH. The NEO Coolcam products works direct without any problem.
Well, I managed to solve the dropped packets by simply inserting a Z-Wave wall plug halfway between my controller and the motion sensor. I guess the range was too far and the plug is now extending it.
Let’s hope there’s no more weirdness from now on
@jphab I’m not sure our issues are related but I hope you perservere. OpenHAB has been Rock solid for me apart from some configuration issues like these.
You need to uninstall the 2.4.0 from the interface before you add the other, they will begin conflicting!
I have had some issues too, What saved me was Remove the Items (unlink and delete) Heal and Reinitialize the device (manual wake every time)… and it began working like a charm!
Withe 2.5 snapshot z wave binding, I am not getting any temperature readings.
The attributes says my sensor is model 0003:1083. Is that correct? I thought that is for the PD01Z, not my PD02Z (the one that looks like a golf ball)
