Neo Coolcam Pir motion sensor
I’ve a Neo Coolcam Pir Motion Sensor. I’ve added it to Openhab and it is regonized as : PD03Z. My controller is a Z-Stick Gen5 from Aeotec.
But I get no events from the motion.
> 2019-07-31 16:46:19.700 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=4, callback=4, payload=04 04 06 31 05 01 22 00 FA
> 2019-07-31 16:46:19.703 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
> 2019-07-31 16:46:19.706 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 4: Application Command Request (ALIVE:VERSION)
> 2019-07-31 16:46:19.709 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 4: Incoming command class COMMAND_CLASS_SENSOR_MULTILEVEL, endpoint 0
> 2019-07-31 16:46:19.711 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 4: SECURITY not supported
> 2019-07-31 16:46:19.713 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 4: Received COMMAND_CLASS_SENSOR_MULTILEVEL V0 SENSOR_MULTILEVEL_REPORT
> 2019-07-31 16:46:19.716 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 4: Sensor Type = Temperature(1), Scale = 0
> 2019-07-31 16:46:19.718 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 4: Sensor Value = 25
> 2019-07-31 16:46:19.721 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Got an event from Z-Wave network: ZWaveMultiLevelSensorValueEvent
> 2019-07-31 16:46:19.724 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Got a value event from Z-Wave network, endpoint = 0, command class = COMMAND_CLASS_SENSOR_MULTILEVEL, value = 25
> 2019-07-31 16:46:19.727 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Updating channel state zwave:device:ZwaveController:node4:sensor_temperature to 25 °C [QuantityType]
> 2019-07-31 16:46:19.735 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 4: Commands processed 1.
> 2019-07-31 16:46:19.738 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 4: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@16acd30.
> 2019-07-31 16:46:19.741 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
> 2019-07-31 16:46:19.745 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
> 2019-07-31 16:46:19.749 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
> 2019-07-31 16:46:19.752 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
> ==> /mnt/shares/Openhablog/events.log <==
> 2019-07-31 16:46:19.694 [vent.ItemStateChangedEvent] - zwave_serial_zstick_ZwaveController_serial_sof changed from 233 to 234
> 2019-07-31 16:46:19.753 [vent.ItemStateChangedEvent] - zwave_device_ZwaveController_node4_sensor_temperature changed from 25.5 °C to 25 °C
The temperature is updating wel.
I tried the following rules:
    rule "Beweging keuken"
    	Item zwave_device_ZwaveController_node4_alarm_motion changed to ON
    	sendTelegram("jeroen","Beweging in de keuken")
and this one:
	Channel 'zwave:device:ZwaveController:node4:alarm_motion' triggered ON
Both with no luck. Anyone who can help me?
Assosiations Group is empty and when I configure ‘controller’ I get the following message:
2019-07-31 16:49:40.313 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Configuration update set group_1 to controller (String)
2019-07-31 16:49:40.319 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Unknown association group 1
You may want to turn off the daily network heal and restart the sensor. I believe there is an issue where the network heal can hang for battery devices and never complete.
After turning off the daily heal and removing & replacing the battery, my sensor behaves properly.
I remember @chris discussing possible daily healing issues with battery devices.
When you get to the channels screen on the controller, click the pencil icon at the top. From that screen you can disable the daily network heal.
Thanks for your reply. I tried that but it’s still the same. Temperature is working but I see no event at motion.
> 2019-07-31 19:53:17.600 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=4, callback=4, payload=04 04 06 31 05 01 22 01 08
> 2019-07-31 19:53:17.603 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
> 2019-07-31 19:53:17.605 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 4: Application Command Request (ALIVE:VERSION)
> 2019-07-31 19:53:17.608 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 4: Incoming command class COMMAND_CLASS_SENSOR_MULTILEVEL, endpoint 0
> 2019-07-31 19:53:17.610 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 4: SECURITY not supported
> 2019-07-31 19:53:17.613 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 4: Received COMMAND_CLASS_SENSOR_MULTILEVEL V0 SENSOR_MULTILEVEL_REPORT
> 2019-07-31 19:53:17.615 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 4: Sensor Type = Temperature(1), Scale = 0
> 2019-07-31 19:53:17.617 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 4: Sensor Value = 26.4
> 2019-07-31 19:53:17.620 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Got an event from Z-Wave network: ZWaveMultiLevelSensorValueEvent
> 2019-07-31 19:53:17.623 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Got a value event from Z-Wave network, endpoint = 0, command class = COMMAND_CLASS_SENSOR_MULTILEVEL, value = 26.4
> 2019-07-31 19:53:17.627 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Updating channel state zwave:device:ZwaveController:node4:sensor_temperature to 26.4 °C [QuantityType]
> 2019-07-31 19:53:17.633 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 4: Commands processed 1.
> 2019-07-31 19:53:17.635 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 4: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1032fba.
> 2019-07-31 19:53:17.639 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
> 2019-07-31 19:53:17.643 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
> 2019-07-31 19:53:17.645 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
> 2019-07-31 19:53:17.649 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
> 2019-07-31 19:53:17.074 [vent.ItemStateChangedEvent] - zwave_serial_zstick_ZwaveController_serial_sof changed from 287 to 288
> 2019-07-31 19:53:17.132 [vent.ItemStateChangedEvent] - zwave_device_ZwaveController_node3_sensor_temperature changed from 24.9 °C to 25.5 °C
> 2019-07-31 19:53:17.592 [vent.ItemStateChangedEvent] - zwave_serial_zstick_ZwaveController_serial_sof changed from 288 to 289
> 2019-07-31 19:53:17.647 [vent.ItemStateChangedEvent] - zwave_device_ZwaveController_node4_sensor_temperature changed from 25.6 °C to 26.4 °C
I have my sensor joined insecurely. I see your DEBUG message saying security is not supported.
Does the sensor flash indicating motion? I believe that is the default configuration.
Yes the sensor is flashing when motion is detected.
I still getting this :
2019-07-31 22:07:42.081 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Configuration update set group_1 to controller (String)
2019-07-31 22:07:42.084 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Unknown association group 1
What I see is that on the frist line It’s
group_1
and the second line `
group 1
` whitout underscore
https://www.cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-list/devicesummary/973
Can someone check if the settings in the database are correct?
 "zwave:device:c93d58f4:node2": {
    "class": "org.eclipse.smarthome.core.thing.internal.ThingImpl",
    "value": {
      "label": "Bewegingssensor Trap",
      "bridgeUID": {
        "segments": [
          "zwave",
          "serial_zstick",
          "c93d58f4"
      "channels": [
          "acceptedItemType": "Number",
          "kind": "STATE",
          "uid": {
            "segments": [
              "zwave",
              "device",
              "c93d58f4",
              "node2",
              "sensor_luminance"
          "channelTypeUID": {
            "segments": [
              "zwave",
              "sensor_luminance"
          "label": "Luminance Sensor",
          "description": "Indicates the current light reading",
          "configuration": {
            "properties": {}
          "properties": {
            "binding:*:DecimalType": "COMMAND_CLASS_SENSOR_MULTILEVEL;type\u003dLUMINANCE"
          "defaultTags": []
          "acceptedItemType": "Number:Temperature",
          "kind": "STATE",
          "uid": {
            "segments": [
              "zwave",
              "device",
              "c93d58f4",
              "node2",
              "sensor_temperature"
          "channelTypeUID": {
            "segments": [
              "zwave",
          "label": "Temperature Sensor",
          "description": "Indicates the current temperature",
          "configuration": {
            "properties": {}
          "properties": {
            "binding:*:QuantityType": "COMMAND_CLASS_SENSOR_MULTILEVEL;type\u003dTEMPERATURE"
          "defaultTags": []
          "acceptedItemType": "Switch",
          "kind": "STATE",
          "uid": {
            "segments": [
              "zwave",
              "device",
              "c93d58f4",
              "node2",
              "alarm_motion"
          "channelTypeUID": {
            "segments": [
              "zwave",
              "alarm_motion"
          "label": "Motion Alarm",
          "description": "Indicates if a motion alarm is triggered",
          "configuration": {
            "properties": {}
          "properties": {
            "binding:*:OnOffType": "COMMAND_CLASS_ALARM;type\u003dBURGLAR"
          "defaultTags": []
          "kind": "STATE",
          "uid": {
            "segments": [
              "zwave",
              "device",
              "c93d58f4",
              "node2",
              "battery-level"
          "channelTypeUID": {
            "segments": [
              "system",
              "battery-level"
          "label": "Battery Level",
          "configuration": {
            "properties": {}
          "properties": {
            "binding:*:PercentType": "COMMAND_CLASS_BATTERY"
          "defaultTags": []
      "configuration": {
        "properties": {
          "binding_cmdrepollperiod": 1500,
          "config_11_1": 1,
          "config_10_1": 5,
          "group_4": [],
          "group_1": "",
          "group_3": [],
          "group_2": [],
          "wakeup_node": 0,
          "config_12_1": 1,
          "config_99_2": 1000,
          "action_failed": false,
          "wakeup_interval": 0,
          "action_remove": false,
          "binding_pollperiod": 86400,
          "action_heal": false,
          "config_1_1": 12,
          "config_7_2": 180,
          "config_8_1": 0,
          "config_9_2": 100,
          "config_2_2": 30,
          "config_3_1": 255,
          "config_4_1": 255,
          "node_id": 2,
          "config_5_2": 100,
          "config_6_1": 8
      "properties": {
        "zwave_class_basic": "BASIC_TYPE_ROUTING_SLAVE",
        "zwave_class_generic": "GENERIC_TYPE_SENSOR_NOTIFICATION",
        "zwave_frequent": "false",
        "zwave_neighbours": "",
        "modelId": "PD03Z",
        "zwave_version": "3.80",
        "zwave_listening": "false",
        "manufacturerId": "0258",
        "manufacturerRef": "0003:108D",
        "dbReference": "973",
        "zwave_deviceid": "4237",
        "zwave_nodeid": "2",
        "vendor": "Shenzhen Neo Electronics Co., Ltd",
        "defaultAssociations": "1",
        "zwave_routing": "true",
        "zwave_beaming": "true",
        "zwave_secure": "false",
        "zwave_class_specific": "SPECIFIC_TYPE_NOTIFICATION_SENSOR",
        "zwave_manufacturer": "600",
        "zwave_devicetype": "3"
      "uid": {
        "segments": [
          "zwave",
          "device",
          "c93d58f4",
          "node2"
      "thingTypeUID": {
        "segments": [
          "zwave",
          "shenzhen_pd03z_00_000"
      "location": "Overloop"
and if the right sensor is decteted? Motion sensor Z-wave Plus NEO Coolcam is what I have.
Could it be that the wrong one is detected? References (Type:Id) 0003:108D,0003:208D
That’s fine.
This looks correct based on the database link you provided.
Has the device finished initialisation? Can you provide the XML file generated by your system for this device please?
Did you look at the configuration options in the database? This may be your issue.
My sensor has a different ID & database entry.
I changed it to “0” but it doesn’t do the trick.
When I trigger the motionsensor it get the following log:
2019-08-01 00:09:01.107 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=2, callback=4, payload=04 02 06 31 05 01 22 01 1A
2019-08-01 00:09:01.110 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2019-08-01 00:09:01.113 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Application Command Request (ALIVE:VERSION)
2019-08-01 00:09:01.115 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: Incoming command class COMMAND_CLASS_SENSOR_MULTILEVEL, endpoint 0
2019-08-01 00:09:01.118 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: SECURITY not supported
2019-08-01 00:09:01.120 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 2: Received COMMAND_CLASS_SENSOR_MULTILEVEL V0 SENSOR_MULTILEVEL_REPORT
2019-08-01 00:09:01.123 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 2: Sensor Type = Temperature(1), Scale = 0
2019-08-01 00:09:01.125 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 2: Sensor Value = 28.2
2019-08-01 00:09:01.128 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Got an event from Z-Wave network: ZWaveMultiLevelSensorValueEvent
2019-08-01 00:09:01.130 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Got a value event from Z-Wave network, endpoint = 0, command class = COMMAND_CLASS_SENSOR_MULTILEVEL, value = 28.2
2019-08-01 00:09:01.134 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Updating channel state zwave:device:jeroen:node2:sensor_temperature to 28.2 °C [QuantityType]
2019-08-01 00:09:01.139 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Commands processed 1.
2019-08-01 00:09:01.142 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@747017.
2019-08-01 00:09:01.167 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2019-08-01 00:09:01.181 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2019-08-01 00:09:01.184 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-08-01 00:09:01.186 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-08-01 00:09:01.074 [vent.ItemStateChangedEvent] - zwave_serial_zstick_jeroen_serial_sof changed from 70 to 71
2019-08-01 00:09:01.154 [vent.ItemStateChangedEvent] - zwave_device_jeroen_node2_sensor_temperature changed from 28.9 °C to 28.2 °C
But no motion event.
You don’t say what version of the binding you’re using?
Please can you provide the XML file that the binding generates?
The binding I use is binding-zwave - 2.5.0.M1
You mean this XML file?
<node>
  <homeId>0xf7dcf9b4</homeId>
  <nodeId>1</nodeId>
  <version>4</version>
  <manufacturer>0x86</manufacturer>
  <deviceId>0x5a</deviceId>
  <deviceType>0x1</deviceType>
  <listening>true</listening>
  <frequentlyListening>false</frequentlyListening>
  <routing>false</routing>
  <security>false</security>
  <beaming>true</beaming>
  <maxBaudRate>40000</maxBaudRate>
  <sleepDelay>1000</sleepDelay>
  <associationGroups class="concurrent-hash-map"/>
  <endpoints class="concurrent-hash-map">
    <entry>
      <int>0</int>
      <endPoint>
        <deviceClass>
          <basicDeviceClass>BASIC_TYPE_STATIC_CONTROLLER</basicDeviceClass>
          <genericDeviceClass>GENERIC_TYPE_STATIC_CONTROLLER</genericDeviceClass>
          <specificDeviceClass>SPECIFIC_TYPE_PC_CONTROLLER</specificDeviceClass>
        </deviceClass>
        <endpointId>0</endpointId>
        <secureCommandClasses/>
        <supportedCommandClasses class="concurrent-hash-map">
          <entry>
            <commandClass>COMMAND_CLASS_NO_OPERATION</commandClass>
            <COMMAND__CLASS__NO__OPERATION>
              <version>1</version>
              <instances>0</instances>
              <control>false</control>
              <versionSupported>1</versionSupported>
            </COMMAND__CLASS__NO__OPERATION>
          </entry>
          <entry>
            <commandClass>COMMAND_CLASS_BASIC</commandClass>
            <COMMAND__CLASS__BASIC>
              <version>0</version>
              <versionSupported>0</versionSupported>
              <isGetSupported>true</isGetSupported>
            </COMMAND__CLASS__BASIC>
          </entry>
        </supportedCommandClasses>
      </endPoint>
    </entry>
  </endpoints>
  <nodeNeighbors/>
</node>
that is fir the controller. @chris meant for the PIR sensor.
Could you tell me where I can find that file?
The file should be in /var/lib/openhab2/zwave and the name will end in _node_4.xml.
There is no such file these are the files in the dir:
So that means that the device is not discovered, and this is why you are getting the errors.
You will need to wake the device up so it can be discovered. If it’s not working, then please provide a debug log showing what happens when you wake up the device.
The binding doesn’t generate a xml when a node is discovered. This is the only file it generates:
The discovery did find the motion sensor:
the temperature sensor is working as you can see but the motion sensor is not sending anything.
I deleted everything several times and add it again but stil the same. Reset the controller. Tried it whit Paper UI and with Habmin.
It sould not really matter, but are you discovering through the PaperUI or through HABmin?
HABmin is recommended for zwave configuration & discovery.
Habmin
