Problem with neo Door/window sensors after upgrade to OpenHab 3.
I had been running Openhab 2.4 when installing my zwave sensors.
Had some minor speed bumps but not any big issues
For some weeks ago I upgraded to OpenHab 3.1.0 and it went quite smooth.
Now one of Neo Door sensor stopped working and I thought it was out of battery. It was on the most used door in our home
Put in a new battery and connect it to the Openhab.
But I can’t get any notification for the sensor.
I can see that the diod is flashing on the sensors.
Turned on debug but cant see any thing in the log when opening the door.
Tried to exclude and include again. Did not get it to work
Tried different way but no luck.
Thought the sensor was broken so I tried another working sensor.
After excluding and include it, no notification was seen in the log.
I have tried to look in the forum but no luck. Issues with Neo sensor but not like this
It seems that for some reason when adding the sensor that its not complete so the sensor doesn’t know what to do when doors is opening.Could my installation be corrupted? Need some advice before reinstalling.
Setup:
RaspBerry Pi
RaZberry
Sensors
Log med debug on.
Node 41 was the last try.
Regards
Jonas
