I can find all API calls except “low_battery”. I can find “battery_health” which gives back a string and 2 options as value “OK” and “replace”.
I tried to create an item using battery_health instead of low_battery, but it didn’t work. Only the undocumented low_battery is giving back “OFF” for battery is ok. But do i get back an “ON” if the battery is low or has to be replaced?
Can someone comment on the 2 different API calls please and try to explain this to me please?
The binding uses the Nest battery_health value in a channel named low_battery to reuse a so called systemwide channel that is the same on a lot of bindings:
low-battery system.low-battery Switch Battery Represents a low battery warning with possible values on/off.
@hr3 provided a link to the readme of the OH1 Nest binding which does not apply to the OH2 Nest binding.
