I wonder, if somebody could help me…
For my new two Nest Protect I installed the Nest Binding v.1.10.0.201705080110. Everything is OK until… I reboot the system; then I am not able to receive the data due to the ‘authorization code not found’ found in the console (see bellow). However, when I change the Pin code in the Nest Developers and change this in the UI then the Nest binding is able to receive the data.
I use OpenHab 2 Build 910.
19:04:43.851 [TRACE] [ab.binding.nest.internal.NestBinding] - Querying Nest API
19:04:43.851 [TRACE] [ab.binding.nest.internal.NestBinding] - Retrieving access token in order to access the Nest API.
19:04:43.851 [TRACE] [ab.binding.nest.internal.NestBinding] - Request: AccessTokenRequest[pinCode=PDMWG3NL,clientId=8615b8a0-f170-48ba-b002-bcaad010eb60,clientSecret=ciNHtQfFXivUH5YXXy9X79nhq]
19:04:43.851 [TRACE] [st.internal.messages.AbstractRequest] - About to execute ‘https://api.home.nest.com/oauth2/access_token?code=PDMWG3NL&client_id=8615b8a0-f170-48ba-b002-bcaad010eb60&client_secret=ciNHtQfFXivUH5YXXy9X79nhq&grant_type=authorization_code’
19:04:44.238 [WARN ] [st.internal.messages.AbstractRequest] - Method failed: HTTP/1.1 400 Bad Request
19:04:44.239 [TRACE] [st.internal.messages.AbstractRequest] - {“error”:“oauth2_error”,“error_description”:“authorization code not found”,“instance_id”:“10d1ee58-7870-4ffa-bf72-9febb83414b7”}
19:04:44.239 [TRACE] [ab.binding.nest.internal.NestBinding] - Response: AccessTokenResponse[accessToken=,expiresIn=,error=oauth2_error,errorDescription=authorization code not found]
19:04:44.239 [ERROR] [ab.binding.nest.internal.NestBinding] - Error retrieving access token: AccessTokenResponse[accessToken=,expiresIn=,error=oauth2_error,errorDescription=authorization code not found]’
Thank you very much in advance:
Michael
